No Spark, No Injector, No Start.. Help Please - Hyundai Forums : Hyundai Forum
post #1 of 9 (permalink) Old 08-18-2006, 09:55 AM Thread Starter
tjb45
Hi, I have a 1999 Excel (Accent). The other day it just wouldn't start, It would crank over fine, but it wouldnít fire. After trying a few different things, we decided to put a jump start pack on it, even though it was still cranking over on its own battery. After about 20 seconds of cranking with the starter pack it fired up and ran fine.
I drove it down to the shops and back with no problems.
The next day the same problem, no firing. It will crank fine (nice and quick) and the battery is only a little over 3 months old.
I've checked the CAM angle sensor, and its getting power, and the earth is fine. I've also checked the throttle position sensor and that is also working correctly.
I ran through the trouble code process and it came back saying there is nothing wrong, but when I tested the Actuator Control Sequence Procedure it came back saying there was a problem with injector 1-2-3-4.
There is defiantly no spark and the injectors are defiantly not working either.
I was thinking it might be the Crank angle sensor, but the test didnít show it as been faulty. I was going to test it but I cant find where about it is located.
Does anyone have any idea's? maybe faulty ECU? or crank angle sensor (If so, where the **** is it??)
I would usually give up at this stage and bring it to a mechanic, but I've fallen on some hard times, and donít have any spare money to spend on it.
Any help is very much appreciated.
Tim
tjb45 is offline
post #2 of 9 (permalink) Old 08-18-2006, 09:57 AM Thread Starter
tjb45
Also, is there any kind of factory alarm/immobiliser? if so could that be causing the problem?
tjb45 is offline
post #3 of 9 (permalink) Old 08-19-2006, 02:45 PM
2001accent
You may try check the fuel system .
1: How long before did you chenge the fuel filter?
2: check the fule pump.
3: IF you can DIY, yank the fuel injector , check and clear it.
Also, one easy way is to check the spark plug. Check the color, gap and smell.
Those stuff maybe give you clue. OR, change 4 new spark plug just cost you 5$.
Keep in mind, corect fire need : FUEL, AIR and SPARK.
BTW, how many mileage on it now?
2001accent is offline
post #4 of 9 (permalink) Old 08-19-2006, 06:53 PM Thread Starter
tjb45
Thanks for the reply.
I've had all 4 spark plugs out, and while cranking the engine there was no spark at all.
Also I couldnít get the injector clips off to check the injector wiring, so I unbolted the fuel rail and pulled the injector rail/injectors out of the inlet manifold, and also, whilst cranking they were not spraying any fuel.
Given that the coils and injectors arenít' operating at all, I donít believe it could be just a fuel filter/fuel pump, as I would still be getting spark. I've checked to see if I can hear the fuel pump turn on but I cant, although I've never really heard it before either.
Iím think its either got to be the Crank angle sensor or the ECM.
Does anyone know where about the Crank angle sensor is located? I'm having real trouble trying to find it.
On a side note, when I did the diagnostic check it read back four 4ís (All find).
I then unplugged the cam angle sensor, and the throttle position sensor. Then did the test again, and it still read back that everything was fine.. Whatís the deal with that?
Thanks for the help.
Cheers
Tim
tjb45 is offline
post #5 of 9 (permalink) Old 08-20-2006, 09:03 PM
dannyd101
I had the same problem. Afriend who owns a diagnostic shop suggested replacing the crankshaft position sensor and it appears to have done the trick.
dannyd101 is offline
post #6 of 9 (permalink) Old 08-22-2006, 04:46 AM Thread Starter
tjb45
Ok, well it was the Crank angle sensor. For anyone interested it is located off to the right of the exhaust manifold, near the bottom of the block. Its easiest to access from underneath the car.
As apposed to the Hyundai Web Tech document it has three wires running to it not two.
A replacement was going to cost $160 Aus from the local Hyundai dealer, I managed to fine one from a single cam engine at the wreckers, which he gave me for free. So it worked out to be a cheap fix in the end..
I'm still a little confused as why the diagnostics told me everything was OK.
Thanks.
Tim
tjb45 is offline
post #7 of 9 (permalink) Old 08-22-2006, 06:12 PM
1x32go
My Crank angle sensor was dissconnected at one stage.
It started once, but itried to start it later on and it just wouldn't kick...sounds similar.
1x32go is offline
post #8 of 9 (permalink) Old 08-22-2006, 08:52 PM
robtemple is an unknown quantity at this point
Originally posted by tjb45@Aug 22 2006, 01:46 AM
[b]..
Thanks.
Tim
[snapback]52542[/snapback]
The ECM didn't store a DTC because when the CAS/CKP was in a failed state, it was during engine cranking. It didn't "know" that you were trying to start it, and therefore it didn't detect the absense of the CAS/CKP signal and set a DTC.
robtemple is offline
post #9 of 9 (permalink) Old 08-30-2006, 09:38 AM
usherly
same thing happened with my car
it didnt through an error after the car wouldnt start
but running a test after letting the car die itself it then gave the error for the cas sensor
usherly is offline
