Brake switch/sensor - Hyundai Forums : Hyundai Forum
post #1 of 8 (permalink) Old 09-15-2011, 10:02 PM Thread Starter
elokito
Brake switch/sensor
Hyundai is well aware of the problem of the the brake switch/sensor under the brake pedal dying, they made the version 2.0 of this switch/sensor and already started sending it to Hyundai dealers. This is covered under warranty but will only get replaced if asked.
the problem is the switch dies out because of humidity, I'm on my third one (version 1.0) I'm waiting for the new ones to arrive given the version 2.0 of this switch went out very quick in my country.
the switch is in charge of sending a signal to the car that the brake is being pressed so that you can change gears, if you are stuck simply remove the cap and press it with something then you can change gears.
I as well as others was really tired of having to press the shift release with something every time so i just stuck a scissor on it until the new sensor arrives (which was kinda of what the dealer here offered me to do while the new sensor arrived, to modify something in the brake which would've given the same effect as sticking a scissor on the shift release).
I recommend exchanging your switch/sensor asap
elokito is offline
post #2 of 8 (permalink) Old 09-30-2011, 11:23 AM
frank1203
Wow, can't believe you just posted this. I have been having issues for the last 6-8 months on my 2010 Tucson where the car would not start. In other words, I crank the key and everything lights fine, but engine not cranking - no nothing.. The "P" for Park or "N" for Neutral would not even illuminate on the dash. Eventually, it started, especially when I moved the shifter to neutral. It was sporadic and the dealer could not locate the issue aftyer repeated visits. Then today... I brought the car in for maintenance and the dealer saw Code C1513 which showed a faulty Brake Switch. It was replaced today and he said that was my "starting" problem. Does that make sense? Is that what you experienced? Not sure how faulty brake switch control would be controlling that starting issue I described but who knows... Please see a prior post of mine whare I explained the issue in detail. Thanks for your input!
frank1203 is offline
post #3 of 8 (permalink) Old 09-30-2011, 12:27 PM
MikDee's Avatar
Drives 2015 Sorento EX V6 AWD Ebony Black
Quoted: 13 Post(s)
MikDee
Many Thanks for the heads up elokito I'll keep a watch on this. I don't know if this applies, or is a related issue, but I've noticed balky shifting on mine unless my foot is squarely, & firmly on the brake. I see this is an issue over on the Sportage forum as well.
A few vehicles I've owned, fixed, or modified, & sold, over the years :
MikDee is offline
post #4 of 8 (permalink) Old 10-01-2011, 08:13 AM Thread Starter
elokito
@frank1203, my tucson showed the shift on the dash just fine, but it could've been the the brake switch on your tucson that died who knows, just make sure you got your brake switch replaced with the version 2.0 I will post pics next week of each of the versions.
@MikDee you mean shifting gears when the tucson is stopped? like from parking to D and D to parking, reverse etc? or do you mean shifting when you are driving, if its when the car is stopped then obviously its the brake switch, and I had a problem with my tucson not shifting gears (on automatic) with difficulty and also had it replaced.
elokito is offline
post #5 of 8 (permalink) Old 02-29-2012, 07:04 AM
IX35 Highlander
hosa85 is an unknown quantity at this point
I have also just had this issue stopping me from starting the car , quite annoying . They have replaced the switch but whilst doing that , "some how" they have unplugged or damaged something and now my reverse camera does not work .
I have been advised if anyone has starting issues due to the switch not working just hold down the start button for 10 seconds and it will override the stop switch and start
hosa85 is offline
post #6 of 8 (permalink) Old 07-14-2013, 01:51 PM
dzlmick's Avatar
Drives Tucson
dzlmick is an unknown quantity at this point
I've got this same issue on my 2010 Tucson. does anyone know if this is a recalled part that hyundai will fix at a service center, or if I can just change out the switch myself?
dzlmick is offline
post #7 of 8 (permalink) Old 07-14-2013, 05:33 PM
Paulas2's Avatar
Drives Hyundai ix35 LM Highlander, 2010, diesel automatic.
Paulas2
Why replace it yourself when the vehicle is still under warranty?
Paulas2 is offline
post #8 of 8 (permalink) Old 07-14-2013, 11:41 PM
MikDee's Avatar
Quoted: 13 Post(s)
MikDee
My 2011 Sportage EX goes in Tues. for this issue! The lights have been going on, & off for a few days now, with balky shifting.
Apparently there is no recall for the 2011 Sportage, or 2011 Tucson, but I've got news for Kia! Mine, & 1/2 dozen others are having these same issues with their 2011 Sportages.
MikDee is offline
