Smart Key Problem - Hyundai Forums : Hyundai Forum
post #1 of 16 (permalink) Old 08-14-2011, 05:43 AM Thread Starter
mabok
Has anyone experienced this problem with their Smartkey?
We have a new ix35 with Media pack and Smartkey. The Smartkey regularly fails completely - there is no response at all either by pressing the door handle button or the key fob. The only way to get in is to take out the small metal key and insert it into the door lock and turning it, then the car has to be started by inserting the key fob into the socket in the console box. Both fobs are the same, and it is not a battery issue - the car is only months old. The car would reset itself to normal usually quite quickly after that, until the next time, which could be in a few days time. When it happens it is like the car is in shutdown mode - all electrics (lights, alarm, etc. ) are dead.
The dealer has changed the door key latch/electronics, but to no avail. They are a bit flummoxed, but we are getting frustrated at the inconvenience this problem causes.
Anyone has any experience on this issue?
mabok is offline
post #2 of 16 (permalink) Old 09-03-2011, 04:32 AM
Hyundai ix35 2010 1.7crdi premium
telboy
Hi, I had similar problems with the remote key not being recognised when I press the door handle buttons. I found that if my iphone and key fob are in the same trouser pocket they seem to interfere with the signal.
Not sure if this helps.
Cheers
telboy is offline
post #3 of 16 (permalink) Old 09-06-2011, 08:51 AM
calamari_ring
Yes, I had the exact same problem within the first month of taking the car..
The interior dome lights and everything not working points to 1 thing - fuse.
In the interior fuse box, under the driver side (I think your driver side is the same as mine ?) the top middle, there is a sort of "catch" that is covering 2 fuses. This is called the "memory latch" or something in the manual.. That came loose..
Just push it till it clicks again.. no problems after that..
calamari_ring is offline
post #4 of 16 (permalink) Old 09-13-2011, 05:32 AM Thread Starter
mabok
Thanks for the reply. I had worked it out myself it was the fuse (no thanks to the dealer) and had re-seated the fuse properly since I posted this thread. Seems to have worked ok since!
mabok is offline
post #5 of 16 (permalink) Old 09-28-2011, 05:22 PM
Gozzy
Mine did it yesterday, dealer found Transit fuse was not seated properly
Gozzy is offline
post #6 of 16 (permalink) Old 06-16-2012, 11:04 AM
Hyundai ix35
nelson88 is an unknown quantity at this point
hallo calmari_ing first of all thanks for allready helping everybody.
now to my problem i heave a problem with my smart key but it isnt by open the car its actually by starting it. when i push the breaks to start the engine everything goes on lights,radio and etc. when i push the start button for the second time everything goes off.
sorry for my bad english
nelson88 is offline
post #7 of 16 (permalink) Old 04-04-2013, 12:49 PM
ix35
bevale is an unknown quantity at this point
smart key problem
My 1x35 (it's about 2 years old, 24000miles) has suddenly cut out on me on 2 occasions within a 3 day period. The problem is the smart key. I had to coast to the side of the road(dangerous), leave the car, lock it and unlock it before it would start again. I'm thinking it might be the key battery thats needing replaced. Anybody else experienced the same problem?
bevale is offline
post #8 of 16 (permalink) Old 12-17-2013, 05:49 PM
Mabookie
Guest
Posts: n/a
Quoted: Post(s)
Ix35 suddenly cut out whilst driving at 110 km/hr
This happened to me on 3 separate occasions, the last time whilst I was traveling at 110km/hr. It has been back to Hyundai on each occasion and they can't find anything wrong.
The car is still under factory warranty and they advise me that they will charge me for any further diagnostic investigations. I wish I hadn't bought a Hyundai now. The service people are rude and do not understand how dangerous it is for the car to suddenly die on you whilst driving at 110km/hr. Does anyone have any suggestions on what to do next?
post #9 of 16 (permalink) Old 04-25-2014, 06:34 AM
Meherzan is an unknown quantity at this point
Could be the brake switch.. As i had problems with it when it wouldnt start coz of the pressure switch
Meherzan is offline
post #10 of 16 (permalink) Old 05-10-2014, 03:42 PM
metror
Hi All
In UK brake/pressure switch is being replaced at service, mine was, now occasionally car does not recognise key is in in car!!!!! "" great servicing""
ix35 4wd manual
metror is offline
