Water Stain From Air Conditioner? - Hyundai Forums : Hyundai Forum
post #1 of 11 (permalink) Old 06-20-2010, 09:47 PM Thread Starter
frank1203
Hi. I am an owner of a new 2010 Tucson (3 weeks old). I have recently noticed something that may be absolutely nothing but I thought I'd ask for opinions. We all know that when the air conditioner in any car is used for excessive time, the car will leak clear water and you will see a puddle under the car where you parked (especially when the weather is very hot). This has certainly been happening with my new Tucson which has not alarmed me when I see the water. What is alarming me though is that when the puddle under the car dries, it is drying on my driveway with a grayish spot or slight discoloration. I checked the water and it appears clear but I'm not sure. I can tell you that when this happened with my other previous Hyundai's, the water dried with no spot at all.
So, I guess the question is - is this spotting normal? And if it is not, is it possible that the car is leaking more than just water? Like I mentioned, it appears to look like water and feel like water but I'm not sure. All I know is that my driveway has many little gray dry spots all over it now.
I'd appreciate your thoughts on this. Thanks in advance.
frank1203 is offline
post #2 of 11 (permalink) Old 06-20-2010, 09:57 PM
joeeey's Avatar
2013 Sonata Hybrid Limited 2014 Elantra SE 2007 Elantra SE
Quoted: 6 Post(s)
I wouldn't be alarmed, It's probably just water. There would be nothing else to leak from the A/C drain other than anti freeze from the heater core. But you would clearly see if you had a coolant leak. It's just condensation. It would not be freon, if it were to vent freon from the A/C drain then your A/C system would drain in a mater or minutes and the A/C compressor would not turn on. I can't explain staining your driveway, so if your still blowing cold don't worry and enjoy your Tucson.
joeeey is offline
post #3 of 11 (permalink) Old 06-21-2010, 06:59 AM Thread Starter
frank1203
QUOTE (Joeeey @ Jun 20 2010, 08:57 PM)
Thanks for your feedback. Your answer seems to be the popular one that I don't need to worry about this. However, something still does not seem right to me. Clear water condensation should not create a grayish stain on my driveway. Everywhere I park, it shows up. My new black top driveway is not looking to good and when I try and clean it up (spray it down with a hose..), the stain does not go away. I'm not expert, but this does not sound like clear water to me. As mentioned, I never had this issue with my previous Hyundai's. I just want to make sure there is nothing wrong. I thinking I should contact the dealer or a Hyundai service department to get thir spin.
Has anyone else experienced this?
post #4 of 11 (permalink) Old 07-06-2010, 03:12 AM
joako
It's possible that the evaporator was coated with something such as oil during manufaturing before final assembly of the car. I would think that this eventually resolves itself.
joako is offline
post #5 of 11 (permalink) Old 07-15-2010, 07:30 PM
Banzy
QUOTE (Frank1203 @ Jun 21 2010, 05:59 AM)
Hey,
I just bought a 2010 brand new Santa Fe just over two weeks ago and I have been experiencing the same thing except instead of leaving a grayish stain mine is looks like water ( but is dry of coarse). My driveway is exposed conrete not asphalt. I took my vehicle into the dealership this morning convinced that there is a leak of some sort. They called back to tell me that it is perfectly fine and the only recommendation they had for me was to put a piece of cardboard down on the driveway and park accordingly. They also said that there is some kind of oil mixed with the water and that is why I am getting stains but it is government regulated to be eco-friendly. They also stated that whether I bought the hyundai or a toyota etc. I would experience the same thing.
I am going to call the sales rep for the region hopefully tomorrow. I find it hard to believe that automotive manufactures are building cars that will satin driveways.
I would also like to note I was told it was because of the kind of driveway I have. There is a chemical reaction as well as my driveway is unable to absorb the liquid unlike an aspalt driveway.
Maybe I should have bought a toyota since that is who I work for. I have been on holidays for two weeks so I am expecting to be razzed on Mon. when I go back. lol
Good luck, I will post my results with the sales rep.
Banzy is offline
post #6 of 11 (permalink) Old 07-16-2010, 12:06 PM
Banzy
QUOTE (banzy @ Jul 15 2010, 06:30 PM)
Hey,
I am going to call the sales rep for the region hopefully tomorrow. I find it hard to believe that automotive manufactures are building cars that will stain driveways.
Talked to the manager of the dealership that I bought the vehicle at today. He pointed out that he is not a mechanic but he has had no other complaints like this and to his knowledge there is no oil base in the condensor. He also stated that to be told to put cardboard down is not the answer. He plans to investigate it and come by my house today to see the driveway. He gave me the reps number and e-mail to contact her. She is on holidays until Mon.
Banzy is offline
post #7 of 11 (permalink) Old 07-16-2010, 10:20 PM Thread Starter
frank1203
QUOTE (banzy @ Jul 16 2010, 11:06 AM)
Hi and thanks for the info. This is Frank the originator of the post. Your updates are appreciated. I would like to share one update as well. I did contact the dealer about this issue two weeks ago, and the person I spoke with said that the staining is normal during the car's "break-in" period. He was not exactly sure what might be mixed in with the water that is causing the stain but he did say its just a result of the new car breaking in and that it should stop on its own at a certain point. Well, I am happy to say that it appears that it has now stopped and I don't see anymore stains on my asphalt driveway (only the stains that were made initially). And believe me , with the hot weather here in my area, there is plenty of condensation under my car! My Tucson just hit 1,000 miles today, so give it some time and keep us informed. Thanks again.
post #8 of 11 (permalink) Old 07-17-2010, 06:02 PM
joeeey's Avatar
Quoted: 6 Post(s)
QUOTE (Frank1203 @ Jul 16 2010, 09:20 PM)
If that is the case then it must be a coating that is applied to the evaporator that will eventually wear off.
joeeey is offline
post #9 of 11 (permalink) Old 07-19-2010, 04:30 PM
TimmyB's Avatar
Quoted: 93 Post(s)
TimmyB is an unknown quantity at this point
I have exactly the same issue in my garage. It could be nothing, but hey, I am also the guy whose water pump gave up the ghost last month with only about 5000 miles on it!
TimmyB
Michigan, USA
2002.5 Hyundai Santa Fe
2006 Kia Sportage
2010 Hyundai Tucson Limited FWD
2013 Hyundai Sonata SE
TimmyB is offline
post #10 of 11 (permalink) Old 07-19-2010, 05:24 PM
Todd Nicholson's Avatar
Todd Nicholson
Mine leaves a grayish, whiteish stain. Almost like a hard water stain. I've had other cars with that same color stain as well, so I'm not sure if it's abnormal or not.
Todd Nicholson is offline
