Hi. My Seat Belt chime is stuck on. I do not want to disable it. How can I troubleshoot why it is on?
Mine is a 2007 Tucson M/T 2.0 FWD For years the AIRBAG light has been on. When it started I was told by the agency that it was a failed contact at the Driver's Buckle assembly. Nevertheless, everything worked fine except for the alarm.
A few months ago I started noticing that sometimes when I turned off the motor and pulled out the key, the seat belt chime still was sounding. Inserting the key, turning it back and forth and pulling it out usually would solve it.
Today when I arrived at work, the alarm would not arm up (Viper model) and when I start up the engine and buckle up, the seat belt chime keeps dinging My immediate supposition is that something is wrong with the key cylinder and it is preventing the seat belt from turning off and the alarm from arming up.
I'd rather not go to the agency because I know the first thing they are going to say is that I have to replace the buckle assembly ($200+ probably) and it still it is not going to solve the problem.
Any Ideas?
Thanks!!!.
Any Ideas?
Thanks!!!.
