Camshaft Position (cmp) - Hyundai Forums : Hyundai Forum
post #1 of 12 (permalink) Old 05-24-2010, 06:09 AM Thread Starter
elkarshofy
HI Guys
I would be glad full if anybody could help me. what does mean this code P0011? for my 2007 hyundai tucson
Camshaft position (CAM) ,intake left front bank 1- timingover -advanced /system performance
elkarshofy is offline
post #2 of 12 (permalink) Old 05-30-2010, 08:17 PM Thread Starter
elkarshofy
Unhappy
anybody help please with this code P0011
post #3 of 12 (permalink) Old 05-30-2010, 08:30 PM
jsinton's Avatar
Quoted: 69 Post(s)
From ODB-codes.com:
What does that mean?
"A code P0011 refers to the VVT (variable valve timing) or VCT (variable camshaft timing) components and the car's PCM (powertrain control module, also called an ECM). That consists of a few different components but the P0011 DTC specifically refers to the camshaft (cam) timing. In this case, if the cam timing is above a set limit (over-advanced), the engine light will be illluminated and the code will be set. The "A" camshaft is either the intake, left, or front camshaft."
"Potential Symptoms
Most likely a P0011 DTC will result in one of the following: hard starting, poor idle, and/or stalling. There are potentially other symptoms as well. Of course, when trouble codes are set, the MIL (malfunction indicator lamp, a.k.a. the check engine light) illuminates.
Causes
A P0011 DTC trouble code may be caused by one or more of the following:
Incorrect camshaft timing
Wiring problems (harness/wiring) in intake timing control valve control solenoid system
Continuous oil flow to VCT piston chamber
Failed timing valve control solenoid (stuck open)"
jsinton is offline
post #4 of 12 (permalink) Old 05-30-2010, 08:43 PM Thread Starter
elkarshofy
Thank you brother for replay , but my car doesn’t has these problem hard starting, poor idle so can you tell me what I can do to fix this problem please
post #5 of 12 (permalink) Old 05-30-2010, 08:58 PM
jsinton's Avatar
Quoted: 69 Post(s)
It could just be a fluke if you have no other complaints. Why don't you clear the code and see if it returns?
jsinton is offline
post #6 of 12 (permalink) Old 05-30-2010, 09:09 PM Thread Starter
elkarshofy
i have tried to clear the code but it returned
post #7 of 12 (permalink) Old 05-30-2010, 09:19 PM Thread Starter
elkarshofy
what about camshaft belt
post #8 of 12 (permalink) Old 05-30-2010, 09:24 PM Thread Starter
elkarshofy
what about camshaft belt, is it cause this problem ?
post #9 of 12 (permalink) Old 05-30-2010, 09:46 PM
2008 Sonata 3.3 LTD 2010 Dodge Ram 1500 Hemi 1995 Ford Taurus GL 2009 Sonata 2.4 GLS
ken99 is an unknown quantity at this point
It could be the CVVT oil control valve assembly needs cleaning. See http://www.hmaservice.com/files/331/.../09-EM-002.pdf. It doesn't list the 2.7 liter in the Tucson, but does list the same engine in the Santa Fe. The P0011 error code is one of those sporatic issues that can apparently be triggered by this problem.
ken99 is offline
post #10 of 12 (permalink) Old 05-30-2010, 10:05 PM Thread Starter
elkarshofy
Is it serious problem ?
