Fuel Tank Vent Filter - 30,000 Mile Service - Hyundai Forums : Hyundai Forum
post #1 of 8 (permalink) Old 02-25-2008, 11:37 AM Thread Starter
steves
I do most of the minor service on my 2006 Azerra and the 30,000 mile mark is rapidly approaching. The owners manual says to replace the "Fuel Tank Air Filter" but there is nothing in the manual on how to do this or even where it is (probably near the fuel tank). Has anyone done this and, if so, what do I need to do other then pay the dealer some outrages amount of money for what is probably a simple job. Thanks in advance.
steves is offline
post #2 of 8 (permalink) Old 02-25-2008, 11:57 AM
cmhj2000's Avatar
cmhj2000
I've done a couple on some Kia's and Hyundais. They're by/along side the fill tube. Online service manuals cover this. http://www.hmaservice.com/
FWIW I've talked to several service managers about this item. Most tell me if you're not one to pack your tank when filling to ignore it.
Want to discuss no nonsense auto maintenance?
cmhj2000 is offline
post #3 of 8 (permalink) Old 09-20-2008, 07:56 PM
armoredfrog's Avatar
Drives '07 Azera TG LTD Drives '12 Elantra MD LTD Drives '15 Challenger R/T
Quoted: 3 Post(s)
armoredfrog
…for those of you who are wondering
…with 39,000+ miles on my Azera, as well as being a technician in a number of different fields for well over 25 years, I just HAD to do it…if nothing else out of curiosity just to see if the Fuel Tank Air Filter DID in fact need replacing…in addition, I’d like to pass on some information that isn’t specifically mentioned in the hmaservice-dot-com Shop Instructions:
- the Fuel Tank Air Filter [p/n 31453-3K500] replacement took 20 total minutes to replace
- the ACTUAL part does NOT look like the dwg depicted in the “Shop Instructions” in that the filter portion appears almost rectangular in the dwg but in fact has a cylindrical body
- the OLD part had a foam pad glued to one side, the NEW part did not
- there are 2 hoses on the filter assy, not 1 as implied in the instructions
- here’s what it took on this end:
TOOLS:
- jack
- lug & torque wrench with 21mm socket
- pliers
- #2 phillips driver
- 1/4 in drive ratchet with 10mm socket & 6 inch extension
REMOVAL:
- remove mud guard [if installed] with #2 phillips head driver
- remove inner-rear fender liner with 10mm socket
- squeeze & remove valve connector on fuel tank air filter
- squeeze and slide hose clamps on both sides of filter assy
- slide filter assy off of mounting tongue
- work hoses off of both ends of filter [twist back & forth]
- voila
REINSTALL:
- slide on hoses hoses [both sides], don’t forget clamps
- slide filter back on to mounting tongue
- push on valve connector [only goes on one way] until it’s seated [clicks]
- reinstall inner fender liner and [if installed] mud guard
- install & torque wheel, remove jack, done
...so, do I think it needed replacing ?? ...…YES, for 2 reasons:
[1] the obvious…the fine print in the Hyundai warranty
[2] the valve spring in the filter assy is clearly constructed very fine gauge wire as viewed through the inner port…and because I’m skeptical that the engineers in Korea didn’t specify some ultra high grade unobtanium for the base metal, I didn’t want to have to replace the filter assy in the middle of a NH winter when the spring failed or simply stuck enough to throw a check engine light (replacing plastic parts in the winter isn’t very much fun when you have to bend or push back clips as part of the removal or reinstall…as some readers are all to familiar with)
…to “the cause”
...it takes more time to do it wrong
armoredfrog is offline
post #4 of 8 (permalink) Old 09-21-2008, 06:25 AM
campoly's Avatar
campoly
Very informative armoredfrog. Thanks for posting that.
campoly is offline
post #5 of 8 (permalink) Old 06-24-2011, 12:26 PM
Harley03joe's Avatar
Harley03joe
QUOTE (armoredfrog @ Sep 20 2008, 07:56 PM)
TOOLS:
- jack
- pliers
REMOVAL:
- voila
REINSTALL:
…to “the cause”
[b]Very Good Post Thank You For It
Harley03joe
96 M-B SL500 White/Beige Gut
05 M-B S 500 Silver/Silver Gut
03 Harley-Davidson 100th Anniversary Black/Silver
05 Harley-Davidson V Nose Trailer Black/ Chrome
07 Hyundai Azera Limited Nice Car
Harley03joe is offline
post #6 of 8 (permalink) Old 06-24-2011, 09:46 PM
Harley03joe
QUOTE (steves @ Feb 25 2008, 12:37 PM)
[b]Harley3joe
post #7 of 8 (permalink) Old 08-15-2011, 03:22 PM
Drives 07 Azera Drives 07 Ram 2500
joezera
If the filter was bad, what sort of symptom would it cause? Would it light up the "Check Engine" indicator on the instrument panel?
Joe
joezera is offline
post #8 of 8 (permalink) Old 08-15-2011, 04:59 PM
Harley03joe
QUOTE (joezera @ Aug 15 2011, 03:22 PM)
Joe
I Have No Idea If It Will Set A code Or Not.
I Put That Post In An June 24, I Just Replaced It At 30,000. Like The BOOK TELL YOU TO DO
