O2 Sensor: Bank 1, Sensor 2 - Page 2 - Hyundai Forums : Hyundai Forum
 5Likes
post #11 of 38 (permalink) Old 04-02-2012, 12:24 AM Thread Starter
hmr1979's Avatar
2006 Sonata - 3.3 L 2006 Azera Ultimate
Quoted: 140 Post(s)
hmr1979 is an unknown quantity at this point
Originally Posted by bikerguy951 View Post
HMR1979,
Thank you so much for your posts and sharing that wiring diagram. They were all very helpful. I have the same OBD2 code, so I am following in your footsteps and will be ordering from fourgreenautoparts shortly.
I just wanted to see if everything worked out okay and your check engine light disappeared. And if there are any gotchas I should look out for.
Thanks again!
No problem, that's the beauty of the internet.
Yes, code went off. I disconnected the battery while doing the exchange. Left the battery off for about 30 minutes; code went off after.
If you are replacing the same exact one as my problem - part number ending in 200 I believe, it's an easy switch compared to the other sensors.
Just make sure you have the same length of wire (if it's not the same length, you will know you got the wrong one). I suggest you change it from the top (the harness connector first) then drop the actual sensor to screw in the hole at the bottom of the car. Unless you have someone that can fish you sensor down to you.
Make sure to have a jack stand because you will be going under the car; I wouldn't risk it with just the jack.
I did have trouble trying to unhook the plug from the top - it's just a plastic clip, just make sure not to break anything.
Oh, also a Hyundai tech suggested that I do this: do this in the morning when the engine is cold. Start the car cold, rev till 2,000-3,000 for 20 secs or so then turn it off. That should make it easier to unscrew the sensor.
Let me know how it works out for you.
hmr1979 is offline
post #12 of 38 (permalink) Old 07-25-2012, 04:37 PM
flyboy480's Avatar
Drives: 2010 Veracruz, Limited
flyboy480
hey there hmr1979
Was the bank 1 sensor 2, the one you figured out. Post cat RH side??
I got a Veracruz with same code that says same thing bank1 sensor 2. P0037
flyboy480 is offline
post #13 of 38 (permalink) Old 08-02-2012, 07:26 PM
Sonata 2006 Elantra 2009
sonataLX is an unknown quantity at this point
Hi,
I am having the same problem with My 2006 Sonata LX, engine light. I searched eBay found the seller (fourgreenautoparts) listing the oxygen sensor. My code came up as 0037 (bank 1 sensor 2) but I am not sot sure which part to order. There is a rear right sensor and a rear left sensor on bank 1 and 2, respectively. Is the bank 1 sensor 2 located on the right side of the vehicle when facing the front of the vehicle or the left?
sonataLX is offline
post #14 of 38 (permalink) Old 08-03-2012, 10:28 AM
After further research, I found some information distinguishing between right & left sides pertaining to oxygen sensor location. While sitting in the driver's seat of the vehicle, the passenger side (your right hand side) would be considered the right side (Bank 1). The driver's side is considered the left side (Bank 2). The OBD code I have for my Sonata is P0037 = Bank 1 Sensor 2, replacement part description would be oxygen sensor rear right if the information is accurate (downstream - after the CAT converter). As a second check I contacted the Hyundai parts dealer & provided a description of the code (Bank 1 Sensor 2) + the vehicle VIN #, they confirmed the part to be #39210-3c200 which is the rear right oxygen sensor. Now I need to confirm the physical location of the oxygen sensor.
sonataLX is offline
post #15 of 38 (permalink) Old 08-13-2012, 11:58 AM
Follow-up.
The right rear oxygen sensor (bank 1 sensor 2) is located on the right side of the vehicle when sitting in the driver’s seat (left side of the vehicle when facing the front of the car). The sensor is located post the catalytic converter in bank 1 & is easily accessible (bank 1 is the side close to the firewall - used 2 jack stands to support the vehicle). As hmr1979 mentioned in an earlier post, run the vehicle for approximately 20 seconds before removing the O2 sensor & then disconnect the battery ( I disconnected the negative terminal). I did not have the right size wrench for the O2 sensor but was able to remove it quite easily with an adjustable wrench. I have read that the vehicle has 2 catalytic converters, one for bank 1 & the other for bank 2. While underneath the vehicle, I was able to identify both right & left rear O2 sensors (banks 1 & 2) both are easily accessible. Both front bank 1 and bank 2 sensors are also easily accessible; they sit on top of the engine, bank 1 by the firewall and bank 2 by the radiator. Also, the replacement part I ordered (thanks to the tip from hmr1979) from Fourgreenautoparts was the exact OEM. I received the replacement OEM O2 sensor in 2 days. A mechanic I know mentioned that O2 sensors are color coded. The replacement part I ordered did have a color coded blue ribbon around the wire which matched the original O2 sensor I had removed ( it also had a color coded blue ribbon).
So far the car is running great, no engine light. Thank you everyone!
hmr1979 likes this.
sonataLX is offline
post #16 of 38 (permalink) Old 08-16-2015, 01:35 PM Thread Starter
hmr1979's Avatar
Quoted: 140 Post(s)
Looks like I am bumping my own thread lol As I got this code again while working on my brake upgrade. Android double din and obd actually came in handy yesterday for me.
So the story goes, as I am doing my brake bleeding, I over spilled brake fluid like true knoob while replenishing the reservoir....I am convinced the over spill landed on the sensor and possibly messing it up. The light came on literally after I got in the car to push on the brakes to get the air bubbles out. Possible?
The CEL is now gone after I washed my car today, so maybe the problem is resolved? Looking back at this thread, this is the same sensor I changed so this would be the newer one.
Does anyone know how to check DIY if the sensor is bad?
hmr1979 is offline
post #17 of 38 (permalink) Old 08-18-2015, 12:34 PM
2015 Genesis Ultimate 2011 Azera Limited
Quoted: 26 Post(s)
srobak is an unknown quantity at this point
Use a multimeter and put a continuity test across the pins on the sensor. I am not sure what the ohm load should be - so other than testing for continuity I'm not sure.
srobak is offline
post #18 of 38 (permalink) Old 08-19-2015, 01:58 AM
Senior Menmber
Karaoke Kop's Avatar
Drives 2008 Azera purchased in 1/2015 Drives & works on 1992 Pontiac Firebird & GF's 2000 Infiniti
Quoted: 532 Post(s)
Karaoke Kop is an unknown quantity at this point
Thanks for bumping your thread. Saw it, read it, & saved it in a special repair file I keep on my laptop.
Karaoke Kop is offline
post #19 of 38 (permalink) Old 08-19-2015, 12:02 PM Thread Starter
hmr1979's Avatar
Quoted: 140 Post(s)
No problem.
I actually was confusing myself, this was in the TG section as it was my Azera and not my Sonata...but I assume it would be the same thing.
My CEL actually has dissapeared...wonder if I Should still trouble shoot it or let it be?
hmr1979 is offline
post #20 of 38 (permalink) Old 09-09-2015, 06:19 PM
drives 2007 Hyundai azera wife 2000 Audi A4
Quoted: 10 Post(s)
oskidunker1 is an unknown quantity at this point
Seems like replacing these sensors should be part of routine maintenance as was the case with my Audi. Wonder why Hyundai does not do this.
oskidunker1 is offline
