Tire Noise Or Wheel Bearing - Hyundai Forums : Hyundai Forum
post #1 of 27 (permalink) Old 01-19-2010, 09:57 AM Thread Starter
2008 Azera Limited
Quoted: 3 Post(s)
opelikamike
ON smooth highway at varying speeds I can hear a rhythmic bumping/thumping noise from the front end of our 2008 Limited with 26,000 miles. It is speed sensitive but I can't tell if it would be a wheel bearing going bad or tire noise from the stock Michelins or maybe one out of balance though I don't feel anything as much as I hear something.
I guess I can take it to dealer to see if they can diagnose. Any thoughts or suggestions on what it might be? I've never been a fan of Michelins and I'll be putting a different tire on when i replace these which will probably be by 30K miles.
Thanks Mike
opelikamike is offline
post #2 of 27 (permalink) Old 01-19-2010, 12:14 PM
jsinton's Avatar
Quoted: 69 Post(s)
Did you try to rotate your tires and see if the problem goes to the rear?
jsinton is offline
post #3 of 27 (permalink) Old 01-19-2010, 12:21 PM Thread Starter
2008 Azera Limited
Quoted: 3 Post(s)
opelikamike
I rotated them at 23,600 but didn't notice then the noise before then. The fronts were on the rear then. I'll rotate them again at 25,600. maybe I should just wait till I rotate them then and see if it goes away rather than waste a trip to the dealer.
I'm not sure what sound a bad wheel bearing would make.
post #4 of 27 (permalink) Old 01-19-2010, 12:35 PM
jsinton's Avatar
Quoted: 69 Post(s)
Sometimes it's hard to tell the difference, but it's more likely a tire problem.
jsinton is offline
post #5 of 27 (permalink) Old 01-19-2010, 03:21 PM
2017 Azera Limited 3.3L
rodneya332
Have you tried putting a pry bar to the CV joints?
rodneya332 is offline
post #6 of 27 (permalink) Old 01-19-2010, 10:41 PM
Fasteddy
Seems like I may have had the exact same problem after I rotated tires for the first time. Hyundai replaced one front wheel bearing but problem did not go away. Thought that maybe it was my imagination but problem got worse. Ended up being that all 4 wheel were either all toeing in or toeing out, can't remember right now. Ended up replacing all tires, with Michelin picking up 30%. I would really have to say the the alignment was the cause. It might be a simple inexpensive check to check your alignment. Time will tell if the alignment was the cause but I am 99% sure, as the thumping is gone. Good Luck.
Fasteddy is offline
post #7 of 27 (permalink) Old 01-20-2010, 10:31 AM
2000 Dodge Dakota 2006 Chevy HHR 2007 Azera
murrag
It the tires same noise on my inlaws 2008 with 23k on it you will have live with it or get new tires
murrag is offline
post #8 of 27 (permalink) Old 01-20-2010, 10:36 AM
boostedfc3s
It's the tires. Mine did the same thing. Hyundai can't design a suspension system worth a ****, so tires cupped with less than 18k on mine when I had it.
boostedfc3s is offline
post #9 of 27 (permalink) Old 01-20-2010, 01:28 PM Thread Starter
2008 Azera Limited
Quoted: 3 Post(s)
opelikamike
I don't see abnormal tire wear on one side of the tires - either inboard or outboard side - but I guess i could have the alignment checked just to make sure all is OK. I don't feel the car pull (it seems to track well with hands off wheel on a flat road).
I would plan to get it aligned for sure when i get new tires so I guess I need to decide whether to get it aligned now and then again when i get new tires or just wait to do it when I replace tires.
Thanks,
Mike
post #10 of 27 (permalink) Old 01-20-2010, 03:13 PM
ColtsKurt
Same issue with my 2007 w/ 27,500. Came here to see if anyone else had it and look what I found!
Thanks, I think...
ColtsKurt is offline
