terryman - Page 2 - Hyundai Forums : Hyundai Forum
post #11 of 29 (permalink) Old 01-16-2013, 05:34 PM
terracan
markdo is an unknown quantity at this point
hi all.. i am having a simular problem
if the glow plug light comes on in the dash the terre will start and if not you could crank it till the grave
in saying that it only comes on for about 1 sec .( temp is usually around 3c)
my first thought was the relays
then temp sensors
so after reading this its down to temp sen
can you tell me the location of these
markdo is offline
post #12 of 29 (permalink) Old 01-16-2013, 05:41 PM
Em-squared's Avatar
markdo.
Fashionista.
Em-squared is offline
post #13 of 29 (permalink) Old 01-17-2013, 09:35 AM
MODERATOR
RBURGOSS's Avatar
Quoted: 7 Post(s)
then temp sensors
The attached service manual pages show where are all the sensors for the 2.9 crdi engine (terracan)
For the ECT (engine coolant temp) sensor, look at second page. The main engine drawing has mistakenly indicated that this sensor is located at the intake manifold, where the glow plugs are. It is located at the thermostat housing intake towards the front of the engine, as showed on Drawing 1, page FLB 24.
Let us know your findings.
Robert B.
Don't forget to participate and vote in the February 2013 ROTM thread at
RBURGOSS is offline
post #14 of 29 (permalink) Old 01-17-2013, 12:07 PM Thread Starter
drives terracan
ernwilson@msn.com is an unknown quantity at this point
i still cant find the 2 glow relays am i thick or what.
ernwilson@msn.com is offline
post #15 of 29 (permalink) Old 01-17-2013, 12:47 PM
MODERATOR
RBURGOSS's Avatar
Quoted: 7 Post(s)
Look inside engine compartment. There are TWO fuse and relay boxes. A large one (No. 1) on the same side of the driver, between the firewall and the fuel filter. The other one is at the other side, next to the battery. This is on LHD models. I don't know if for RHD models this changes, but its there.
The glow relay (and main fuse) is inside this second fuse and relay box.
File Type: jpg TERRACAN RELAY BOX 2 ENGINE COMPART.jpg (89.7 KB, 11 views)
Robert B.
RBURGOSS is offline
post #16 of 29 (permalink) Old 01-24-2013, 02:05 PM Thread Starter
drives terracan
hiya rob ive checked both glow heaters they are ok. ive checked relay in box in engine compartment thats ok. on my diagram it shows 2 relays but i cant find the second one.i still have 0 voltage on 1 glow plug the other one work fine.
post #17 of 29 (permalink) Old 01-24-2013, 03:51 PM
MODERATOR
RBURGOSS's Avatar
Quoted: 7 Post(s)
Yes, its tricky because the diagram makes you think both relays are located at the same place (next to each other)
Glow relay 1 is inside the fuse and relay box 2 in engine compartment. Glow relay 2 is by itself, outside this same box, bolted to the side, between the fuse box and washer bottle filler neck.
Robert B.
RBURGOSS is offline
post #18 of 29 (permalink) Old 01-30-2013, 07:43 AM Thread Starter
drives terracan
hi rob ive check both air heater plugs and they are ok. i tested 1 relay in box in engine bay and thats working ok. on electrical drawing it shows 2 relays but i dont know where the 2nd one is. i still get 12v on one plug but nothing on the other. i have asked hyundai dealer but they havent got a clue.
post #19 of 29 (permalink) Old 01-30-2013, 08:09 AM
MODERATOR
RBURGOSS's Avatar
Quoted: 7 Post(s)
Look at my previous post (#17). The second relay is outside this box, bolted to a bracket on the fender inside. The second relay is a bit bigger than the one inside the box. It has no markings but its easy to find. (Heater relay #2)
Robert B.
RBURGOSS is offline
post #20 of 29 (permalink) Old 01-31-2013, 09:19 AM Thread Starter
drives terracan
looking at your glow relay page it must be a LHD one mines a RHD. Cheers.
