Hard start when warm - Hyundai Forums : Hyundai Forum
 1Likes
post #1 of 11 (permalink) Old 01-03-2013, 08:30 AM Thread Starter
terracan 2.9 diesel
mickph is an unknown quantity at this point
Hi
i bought my terracan a few months back and it has a problem starting when warm,first time start when cold,engine check light flashes when revved but runs great but stop the engine and it takes a lot of turning over to start,it has cut out twice after engine light on for over 30-40 secs.
Thought it may be old brake switch problem but it`s had a replacment at some time with the newer part number or could it still be the switch,anyone help
mickph is offline
post #2 of 11 (permalink) Old 01-03-2013, 10:20 AM
MODERATOR
RBURGOSS's Avatar
Quoted: 7 Post(s)
Welcome to the forums.
First things first: You should get your car scanned for error codes and sensor/fuel management operation.
There are many situations causing a hard engine start when hot. Find attached troubleshooting chart form service manual. Some situations may be easy and cheap to correct (clogged air filter), while others may be complicated or expensive (injector replacement due to needle contamination).
You can download the fuel management service manual here Download FLB.pdf from Sendspace.com - send big files the easy way and have it in hand when contacting a good mechanic.
Let us know your findings.
File Type: jpg TERRACAN POOR START WHEN HOT TS CHART.jpg (190.1 KB, 29 views)
Robert B.
Don't forget to participate and vote in the February 2013 ROTM thread at
RBURGOSS is offline
post #3 of 11 (permalink) Old 01-03-2013, 10:59 AM Thread Starter
terracan 2.9 diesel
Hi
had full service 2 months ago new filters etc ,car has been scanned no codes present,fuel line with none return valve fitted all fuel lines clear,all air ways clear runs excellant no power loss,
mickph is offline
post #4 of 11 (permalink) Old 01-03-2013, 12:07 PM
MODERATOR
RBURGOSS's Avatar
Quoted: 7 Post(s)
Originally Posted by mickph View Post
Hi
If no error codes are present and car had full service with new filters just 2 months ago, I would suspect fuel (maybe contaminated fuel), or possible air leak into fuel filter or lines (check hose connectors for cracks).
Did this problem started all of a sudden or it began mildly then got worse with time? Did it happen after something was done to car or engine? (Like after a fuel fill up?)
Robert B.
RBURGOSS is offline
post #5 of 11 (permalink) Old 01-03-2013, 01:44 PM Thread Starter
terracan 2.9 diesel
Problem started suddenly,there was`nt any work done around that time and was 1/2 way through a tank of diesel,the engine light only comes on when travelling i can rev the car as high as i like at standstill and no check lights come on,thanks for all suggestions,macadams rescue breakdown `mechanic ` came out last night just said `stick some forte in`did not even lift bonnet or check anything
mickph is offline
post #6 of 11 (permalink) Old 01-03-2013, 03:21 PM
MODERATOR
RBURGOSS's Avatar
Quoted: 7 Post(s)
Well my friend, if the Forte additive (tell us which one) works, then it means your problem was around carbon buildup in injectors (chambers, valves, etc).
Let us know your results.
Robert B.
RBURGOSS is offline
post #7 of 11 (permalink) Old 01-03-2013, 05:27 PM
Em-squared's Avatar
Hi and mickph.
Fashionista.
Em-squared is offline
post #8 of 11 (permalink) Old 01-07-2013, 05:08 AM Thread Starter
terracan 2.9 diesel
Hi
thanks for welcome em-squared,tried valve cleaner and 12 volt fuel pump in place of hand primer pump both made no differance looks like it`s off to my local garage this week will post reults soon as i get it back thanks
mickph is offline
post #9 of 11 (permalink) Old 01-17-2013, 04:40 AM Thread Starter
terracan 2.9 diesel
Hi thanks to all with suggestions
been to diesel specialist seems injectors are not holding pressure and returning too much diesel so looking for replacement injectors and hope it cures the problem.
Is it possible to fit a filter to the high pressure system or would it reduce the pressure too much,may help with any metal filings from the pump as it seems to be a problem on some cars and i would like to protect the injectors if possible
mickph is offline
post #10 of 11 (permalink) Old 01-17-2013, 10:46 AM
MODERATOR
RBURGOSS's Avatar
Quoted: 7 Post(s)
That is a trick question...
If fuel pressure is within specs, as monitored by the rail pressure sensor, and the injectors are not holding the pressure, then by reducing the pressure you will probably fix the injector problem, but cause a "low pressure" error along the main rail. OTOH, "pressure" is the big secret behind the CRDI technology. By reducing the pressure, you will also reduce engine efficiency. Have in mind that this engine works with 1600 bar pressure, but newer engines as the one on the Santa Fe, work at 2200 bar. Some high end CRDI engines (Audi, VW, Porsche and BMW) work at 2600 bar.
If fact, the ONLY difference between the 150 Hp Terracan and the 162 HP Terracan, is PRESSURE!, and of course, a couple of different parts that can handle the higher pressure, like the injectors...
Robert B.
RBURGOSS is offline
