 Hyundai-Forums.com > Hyundai Models > Elantra & Lantra Forum > 1G (1992-1995) Elantra & Lantra
> Driveshaft Removal 94 Elantra
miatawnt2b
post Oct 17 2004, 12:16 PM
Drives: 94 Elantra
I need to replace the C/V on a 94 Elantra and just wanted to make sure the axle just slides out from the trans.
J
gordo
post Oct 19 2004, 07:30 PM
Super Member
Drives: 2002 Elantra
It takes a bit of effort to get the axle out - Hyundai's shop manual recommends careful use of a pry bar. You don't want to dig it in too far otherwise you'll tear up the axle seal.
There is a retainer ring on the end of the axle that will need to be replaced when you are re-installing.
Gordo
Dr. Hundi
post Oct 20 2004, 06:26 PM
Group: Mod Emeritus
Drives: Cressida
Yes Gordo, that is correct, however the new or re-conditioned driveshaft should come with a new retainer clip on it.
You will also be required to remove the gearbox oil so that it doesn't end up all over you and your floor.
However you can always remove the driveshaft and then plug the hole with a rag, whilst you quickly grab the other shaft.
Remember to place the CV joint into the gearbox carefully, you don't want to tear or split that driveshaft seal!
Good Luck!
No New Posts Elantra 2000 Ecu
diference and compatibility
2 bloque 340 18th October 2008 - 06:41 PM
Last post by: Jimmy_pop15
No New Posts Elantra Reliability
12 mkaresh 1,632 14th October 2008 - 12:58 PM
Last post by: mkaresh
No New Posts 94 Scoupe Torqu Specs
4 bandit 678 181 9th October 2008 - 03:40 AM
Last post by: tomlin19
No New Posts Topic has attachmentsElantra Pictures
11 ambassador 2,386 7th October 2008 - 06:11 PM
Last post by: Kayakman
No New Posts Elantra 2004 Rim Pattern
i need winter tires can i use a 14 inche
0 cachorros 119 6th October 2008 - 09:09 PM
Last post by: cachorros
23rd November 2008 - 05:53 AM
