Hello fellow Sonata freaks, here's what I spent my Friday afternoon doing .. installed my roadyxt semi-permanently.
I decided to put the antenna on the hood since it's black and sort of matches the windshield washer nozzles. What do you think ? I would have preferred to leave it on the dash but without the ground plane I found it cut in and out quite a bit. Mounting it on the metal seemed to foot the bill :banana: I placed it on the roof and trunk but I found it very "intrusive" looking and it didn't compliment the smooth lines above the belt line, I didn't care for it.
As for the roady, as you see I stuck it over the passenger airbag indicator - ha ha I guess I've decided I wanted that location bad enough to cover it up. It's a perfect spot, within very easy reach and the FM transmitter is literally an inch from the radio, the sound and clarity is great !! Should I be concerned about the air bag light ? Does it indicate a problem if the passenger bag isn't working ? Hmm, maybe I'll reconsider the location.
Oh also decided to paint the calipers .. what do you think of the bling ? :whistling:
This post has been edited by babstude: Apr 14 2006, 08:58 PM
