No Brake Light Or Back-up Lights |
Apr 11 2006, 03:31 PM
Status:
Drives: 1998 Accent Manual
My brake lights and back up light don't work. The bulbs are fine, the fuses look OK, and I replaced the T/L fusable link with the horn one to see if that was the problem, but they still didn't work.
Any ideas?
Jae
Apr 12 2006, 12:47 PM
Status:
Thanks johnc,
I'll give that a try and let you know how it goes,
jaew
Nov 12 2007, 05:23 PM
Status:
Drives: Hyundai Elantra
i am having the same problem with my 2000 hyundai elantra! i have replaced bulbs and checked fuses but still not working. You asked if it was just on one side mine are out on just the left side. where is this ground wire located you said to check?
Nov 14 2007, 06:33 PM
Status:
Drives: 1999 hyundai Accent 1.5L SOHC
I had a similar problem with my accent 99... I was driving at night and suddenly all lights went off, only my front right corner light was on.. I verified fuses and bulbs and they were fine... Taking in consideration that it was late.. i tried this... I connected a cable to the positive of the battery, took of my left corner light, took the postive cable and connected the cable to the one connected to the baterry. and Voila.. All lights on again..... I got home and disconected the cable.. The next day i checked everything and it was fine, all grounds were fine..
What i did i took the positive of the working light, connected a relay , and then connected the relay to the other non working side and everything worked fine.....
A few Days ago a decided to connect everything how it was, just to see.. and everything was working again... Strange thing....
Nov 15 2007, 04:55 PM
Group: Super Mod
Status:
Dear jaew,
Both the brake lights and the backup lights went out at the same time? That does indicate an improper ground. The brake lights are actuated from the switch under the brake pedal under the dash, but the backup lights are actuated with a switch on your shifter rod. Two different source of power in, however, the rear lights do share one ground out. Check your ground connections again.
Byron
Jan 28 2008, 12:00 PM
Status:
Drives: 2000 Hyundai Tiburon
Where exactly is this grounding cable?
I have the exact problem: Brake lights are out (both), but the Third Brake Light (LED on spoiler) works. All other lights/signal lights, headlights, driving lights, etc. work. No fuses are blown. Bulbs are not burnt.
So I am guessing the problem is with the ground as well... Is it in the bulb assembly area (you know, behind the felt-lined cover with 2 screws), or elsewhere in the trunk area??
Thank you.
Feb 17 2008, 01:25 PM
Status:
Drives: 1998 Hyundai Accent RHD
Hi,
I am having the same problem with my 98 accent. Both the backup lights and hte brake lights are not working. It's not the fuse. I can't figure out where this ground wire is that you speak of. Could you please be a little more specific about where it is and how to replace/fix it once i have determined that it is faulty?
Thanks so much for your knowledge. We all truly appreciate it.
Similar Topics
Similar Topics
