PomansAWD, I do hope that is the problem with mine, the 2001 santy I got has hyundai factory rubber mats that do not have a large capacity but if there was snow and it melted, then the next day more snow was brought it I could see how this cycle could leave the standing water under the carpet and sound dampering foam. There also is usually not enough air movement for how ever long you are in the car to dry out what was deposited on that day. I also have a sunroof on mine so I will keep an eye on that to because it might be on of the drainage tubes blocked. I got a response from CJS and he traded the vehicle in last year and never got to the bottom of the problem. I am keeping the sound foam out to dry out and leaving the carpet not tucked back under the molding to watch the next time it rains to see if water appears from the bottom. Thanks for your input and I will update when something happens.
Ryan
