QUOTE(FaniG422 @ Jan 28 2006, 02:08 PM)
So...a while ago I was experiencing transmission problems (slippage and such) and then one day it wouldn't shift at all. I got on the highway and at 60 mph it would be at 4000+ rpms. Also, when I would come to a stop and then try to go again, it would not accelerate and when it would, it would just rev. So, I got a new throttle pos sensor put in and a new ECM put in. As soon as I got the car back the check engine light came back on. The idiot...I mean mechanic...came back and ran the computer scan, and said that he reset it since the transmission was still reading from the old ECM. Everything worked fine for 3 weeks and now it's doing the same EXACT thing!!! My check engine light came back on and Autozone said it read a P0501- vehicle speed sensor; they said that there was no response from it. It's a 1999 Hyundai Accent GL- V4.
So, finally, my questions are:
1. Where is the VSS in my car? (I have heard under the hood, under the dash, behind the speedometer, and on my right wheel.)
2. What does the VSS look like?
3. Autozone said there was no response, so do you think the VSS is broken, or just not hooked up properly?
4. Could it possibly be something else?
I have done quite a bit of research, but I've just confused myself even more :(
Responders: Thank you for your time and any input would be greatly appreciated. Please try to "dumb-down" any instructions or explanations that you may have, as I am not too mechanically inclined.
[right][snapback]28334[/snapback][/right]
I have this exact same issue, i tested my sensors and the only thing reported back to me a P0500 Speed Sensor "A", would this code be the cause to the problem?
Trevor
