QUOTE(caldom @ Jan 15 2006, 05:57 PM)
. i tested the output of the alternator and is only charging when the engine is cold but cuts off 2 mins after the engine has started any other thoughts thanks
[right][snapback]27293[/snapback][/right]
Hi guys, i'm a newbie in need of some help, my wife has a 1.6gls Lantra '95 It still has an intermediate charging prob after 10 months, i have to charge the battery every night otherwise if she drives it next day it will die. I've had 3 alternators and 2 batteries so far and the symptoms persist, as above, it charges when cold (14.5volt) but 5mins later the charge rate dropes to 12.5volt and stays there, sometimes it drops to 10volt. One thing that does puzzle me is, when ever the car dies due to a flat battery there is no warning from the battery charge light on the dash, it only seems to illuminate when ignition is switched on with a fully charged battery, does this have any bearing on my prop, i've had the dash apart and all bulbs/connectors are ok, my work shop manual says its impperative that all HT leads are positioned correctly otherwise electrical probs can occur, is this right 'cause mine all lay over each other! Thanks in advance.
