 Hyundai-Forums.com > Hyundai Models > Amica & Atoz Forum
> Atos Low Beams Don't Work, Atos low beams
nedatlund
post Dec 10 2005, 07:17 AM
Drives: Hyundai Atos
I have the problem that the low beams don't work but the high beams do. In case this is a hint, the light adjuster (roller from 0 to 2), doesn't do anything.
I have read in this forum before that replacing the bulb doesn't work.
There was also mention of a relay that could be replaced. My simple manual doesn't tell me which one it is -- As far as I can tell, the relays are next to the fuse box underneath the steering column (with the hood release on the other side).... Is there any hope if the relay is replaced, or do I have to make a trip to the dealer.
Any hints in any direction would help
ned
Muriel&Roland
post Dec 22 2005, 10:47 AM
Drives: ATOS Prime GL Clim 2001
Hello nedatlund,
You live in northern europe, I guess driving with day-light, is that right ?
Then, I'll be sure you'll have to replace the bulb...
There are 2 filaments in each H4-bulb, one for low-beam (must be broken), and one for high-beam (must be OK).
Have a look at this before considering the replacement of a relay... bulbs are less expensive, and as I wrote, it's most likely the bulb has to be changed.
Replace both, the right and left bulbs in order to have the best lighting you can on your car.
If you only replace the bad one, the brightness of both beams should be slightly different.
Hope it helps,
Best regards
Roland
No New Posts Topic has attachmentsLower Arm Assembly - Can't Disconnect
Having trouble getting the front wheel hub off
4 brokencar 21 1st December 2008 - 05:49 PM
Last post by: theiceage05
No New Posts Low Speed Steering Wheel Squeak
7 frozentax 470 19th November 2008 - 08:01 PM
Last post by: frozentax
No New Posts Lowering Springs/coilovers
Lowering heigh
4 Renegade2006 649 11th November 2008 - 08:59 AM
Last post by: wheel_of_steel
No new Lowring Springs
33 DalwinCo 734 29th October 2008 - 02:23 AM
Last post by: r4square
No New Posts Low End Torque
7 Tiburon_03 137 26th October 2008 - 08:13 PM
Last post by: Tiburon_03
3rd December 2008 - 01:15 AM
