 Hyundai-Forums.com > Hyundai Models > Accent Forum > 1G (1995-1999) Accent > 1998 Hyundai Accent Automatic Trans Problem
 1998 Hyundai Accent Automatic Trans Problem, Accent Trans
JackStripey
post Dec 6 2005, 09:37 PM
Drives: 1998 Accent Auto Trans
Status: OFFLINE
Hey guys,
Great site BTW!!! Ok so here is my question..
I have a 1998 Hyundai Accent Sport..auto trans with the overdrive button on econ button. Right now my car is sitting because it does not have reverse..park works fine. WHen I put the car into drive and pull away all seems fine until the car has to shift to the next gear...When it tries to shift to the next gear the rpms go up..as if it is not going to make it to the next gear..I left off the gas..press the gas slowly and it finally jumps into the next gear with a thud. I can drive it like this as long as the overdrive button is off...when the overdrive button is on it tries to switch up another gear (into overdrive I assume) and I have to go through the whole process of letting off the gas..pressing it slowly and finally it'll go up into OD. Now some background info...this problem happened suddenly...there was never any tranny slipping prior to the reverse going and the other problems. The tranny worked well then one day I put it into reverse to back into a parking spot and boom no reverse..no thuds when I switched to reverse..no slipping prior no signs that there may be a problem at all. Does anyone have any advice before I take her to a shop...I'd hate to get rooked into buying a new tranny if it doesn't need one.
Thx Jack
User is offlineProfile CardPM
QuoteReply
mvftw
post Dec 7 2005, 09:34 AM
Drives: 1997 Accent
Status: OFFLINE
Same problem happened to me 2 months a ago. I dropped the pan and changed the fuild and filter. It takes 4 qts (u.s.), use only SPIII from Hyundai or Mitsubishi. Go to an auto parts store and buy Lucas Tranny Fluid Fix (1 qt. u.s.). Put in 3.5 qts of the SPIII and .5 qt or a pint of the Lucas. This is the cheapest fix you can do! Give a day or 2 to go through the tranny. Also you MUST check the tranny fluid hot and it Neutral, not Park. Mine has been fine for 2 months now. If it still is bad, the next step would be to replace the 2 sensors in the tranny, cost about $45 (u.s.) for the pair, ez job.
QuoteReply
JackStripey
post Dec 7 2005, 11:01 AM
Status: OFFLINE
Thx alot for the tips man...yeah I did I search last night on this forum and it seems that alot of us have had this type of problem.
QuoteReply
Hyuandiowner
post Dec 19 2005, 10:17 AM
Drives: 1998 Accent GL 4dr 1.5l sohc
Status: OFFLINE
I just experienced the same exact thing as Jack did, yesterday in my 98 Accent GL ...
Any reason to suspect to the pulse generator?
Of course, no one local that can look at and work on this for me...will need to see if I can drive about 50 mi to nearest dealer.
QuoteReply
duke
post Dec 19 2005, 11:21 AM
Community Advisor
Group: Community Advisor
Drives: 2007 NF Sonata 2.4L
Status: OFFLINE
Jack,
have your dealer check the end-clutch. It may has lost the "C"-clip, or need replacing. This is a maximum 2 hr. job.
QuoteReply
Hyuandiowner
post Dec 19 2005, 12:20 PM
Status: OFFLINE
Thank you very much Duke...I did manage to make an apointment for tommorrow AM.
Other than not being able to go in Reverse and hard shift from 2nd to 3rd...any major issues with driving this car in current condition for 50 miles (sorry not sure of km conversion)?
QuoteReply
Hyuandiowner
post Dec 20 2005, 01:49 PM
Status: OFFLINE
Duke,
Some sad news from the dealer...they just said need new trany...$2,400 US
Can't believe this would just go out w/o any warning whatsoever.
Any other thoughts?
QuoteReply
Hyuandiowner
post Dec 20 2005, 05:19 PM
Status: OFFLINE
Dealer was able to find a used trany w/39k mi on it. Brought cost down to around $1700. They said replacing the filter and fluid not likley to help...dealer ploy to get more biz??
I'm w/o much choice at this point...got to have car to get to work--120 mi daily.
Thanks again for having a Forum for us to use!
QuoteReply
Omimiles
post Jan 9 2006, 10:36 PM
Drives: Hyundai Accent
Status: OFFLINE
I'm expecting the same problem, I will made the swap to a standard transmission, a year ago, the converter stop doing his work...this time the tranny doesn't want to shift from 2 to third, but the tranny is doing a very loud noise...
QuoteReply
crzyntn73
post Feb 7 2008, 01:35 AM
Drives: 1998 hyundai accent gl
Status: OFFLINE
thanks for the great tip mvftw, i do have one question for you though. when you were changing the fluid did u replace the tranny filter as well? thanks so much. one more question, you mentioned changing the sensors in the transmission, where are they and what are they called? i went to advance auto and the guy told me there were no sensors for the transmission, but you seem like you know more about it that him. by the way my car is a 1998 hyundai accent, 1.5 liter and automatic with overdrive. thanks so much in advance, i am on a fixed income and need all the help i can get.
This post has been edited by crzyntn73: Feb 7 2008, 06:59 AM
QuoteReply
bpriest_119
post Jun 3 2008, 02:51 PM
Post #11
Drives: 2001 Accent
Status: OFFLINE
I seem to be having a similar problem.
My wife was driving to work yesterday and all-of-a-sudden, our 2001 Accent would not shift... she was able to make it back home at 15 mph.
She pretty much told me almost the same thing JackStripey said:
"WHen I put the car into drive and pull away all seems fine until the car has to shift to the next gear...When it tries to shift to the next gear the rpms go up..as if it is not going to make it to the next gear..I left off the gas..press the gas slowly and it finally jumps into the next gear with a thud.... this problem happened suddenly...there was never any tranny slipping prior to the reverse going and the other problems. The tranny worked well then one day I put it into reverse to back into a parking spot and boom no reverse..no thuds when I switched to reverse..no slipping prior no signs that there may be a problem at all."
When she got home, I found out there was no reverse.
I checked the Tranny fluid...it was low and brown. So, I changed the filter and fluid... and ran it a little, but still no reverse. I'm too impatient to wait a day or two as mvftw suggested... I hope its just a matter of time.
The pan didn't have any remnants of metal other than a very small amount of fine shavings on the magnets.
We bought this car around 3-4 months ago with 81,000miles. My wife drive 70+ miles a day round trip to work... so we are at about 86,000 now. Before we bought it I checked the transmission fluid and it didn't look dark or dirty...nor did it smell burnt.
2001 Accent GL 1.6L Automatic
Any ideas, suggestions, experience?
Thanks for your time.
Brian
QuoteReply
sTYZ
post Jun 5 2008, 10:32 PM
Post #12
Drives: 95 accent 12V
Status: OFFLINE
I had the same problem. How i fixed it was i went to napa and bought sea foam for auto trannies. put it in and drove for about a mile and all my problems went away.
QuoteReply
Yarm
post Jun 21 2008, 07:05 PM
Post #13
Drives: 2005 TUCSON
Status: OFFLINE
Hi I am new to this form , I installed a used trans for a guy and took the old one apart to see what had broken in side ,well it was not the end clutch or bearing , there is a splined shaft that one of the drums is splined to and the splines where striped on the drum ,so the shaft turned and the drum did not ,all the clutches where good as new only damage was this spline I searched on the net to get a price on this drum and it was around 200 dollars and a lot of labor to replace .I know see why people put in a new trans or a good used one, this is what i found hope it helps
This post has been edited by Yarm: Jun 21 2008, 09:48 PM
Attached thumbnail(s)
QuoteReply
> Link To Us
> Similar Threads
Autoweek Review Of 08 Accent Se
Forum : 3G (2006+) Accent
crayb 24 2 Yesterday, 11:48 PM
By: mrblank
Hyundai Accent '01 Starting Problems
Forum : 2G (2000-2005) Accent
Palin 11 0 Yesterday, 10:15 PM
By: Palin
2000 Hyundai Grandeur - Power Window Fuse
Forum : Grandeur & XG Forum
emsah7 5 0 Yesterday, 07:15 PM
By: emsah7
Automatic Tranny + & -
Forum : 4G (2006+) Sonata
Goomba 44 3 Yesterday, 06:54 PM
By: lecatpuke
2009 Hyundai Elantra?
Forum : 4G (2007+) Elantra
darnell89 58 2 Yesterday, 12:53 PM
By: darnell89
8th September 2008 - 03:18 AM
