 Hyundai-Forums.com > Hyundai Models > Elantra & Lantra Forum > 3G (2001-2006) Elantra > 2001 Elantra Rear Brakes
 2001 Elantra Rear Brakes, Brake Noise
mrfrankd
post Nov 17 2005, 01:30 PM
Drives: 2001 elantra
Status: OFFLINE
Hi all was wondering if anyone had a fix for the rear brake noise I am getting on a 2001 Elantra.I pulled the drums off and inspected the drums and shoes all looks fine. Then I adjusted the brakes cleaned everything and still get noise .It occurs as the vehicle is comming to a stop last 10mph to stop. Any ideas?
User is offlineProfile CardPM
QuoteReply
saugen48
post Nov 17 2005, 01:35 PM
Drives: (2) 2002 Elantra VE's
Status: OFFLINE
What kind of noise are you talking about?? Is it a squeal or grinding?? Anything movement wise transfered through the brake pedal???
QuoteReply
mrfrankd
post Nov 17 2005, 03:34 PM
Status: OFFLINE
no pedal pulsation sounds more rotational I guess a rotational creaking sound I looked over the springs and looked for maybe a ridge in the drum that was scraping along the side of the shoes,its got me puzzled I might just change out the shoes to see if it stops. Thanks
QuoteReply
shawn418
post Dec 28 2007, 10:53 PM
Drives: 2001 Hyundai Elantra GT
Status: OFFLINE
I too am having the same problem. Although the noise is only occasional. Any ideas? I thought that I may have gotten dirt in there but I can't find anything. The grinding noise just started happening. If the brakes are going bad, isn't there a warning signal? any help is appreciated.
QuoteReply
shawn418
post Dec 31 2007, 01:04 PM
Status: OFFLINE
QUOTE(shawn418 @ Dec 28 2007, 10:53 PM)
An update. As I was checking it out today, the noise went away but as my speed decreased to around 10 mph, the grind came back. Again any info is appreciated.
QuoteReply
byronguidry3732
post Dec 31 2007, 01:13 PM
Group Icon
Group Icon
Group: Super Mod
Status: OFFLINE
Dear Mr Frank and Shawn,
Yes, I know exactly what is wrong with your rear brakes...the hold down springs are worn!! These are the springs that secure the brake shoes to the backing plate. Specifically, these hold the shoes at the right tension so you don't get chatter or squeal noises.
1) Replace those two hold down springs first
2) Did this fix the problem? If no, recommend you clean out all of the brake dust with a low VOC spray cleaner like this one: http://www.crcindustries.com/auto/content/...px?PN=05084&S=Y
3) did this fix the problem? If no, recommend that you get your brake drums turned to remove the hard glaze on the braking surface.
Byron
QuoteReply
Hyundaiownersclub
post Jan 1 2008, 07:38 PM
Drives: Tucson
Status: OFFLINE
Or modified Hyundai brake shoes as for 5 years they made faulty ones which caused noise -most models suffered this problem
QuoteReply
Sammi357
post May 16 2008, 11:47 AM
Drives: 2002 Hyundai Elantra
Status: OFFLINE
2002 Elantra, only 20k miles...does the same scratchy, rotational noise in rear brakes.
checked and adjusted them and the noise went away briefly, then came back.
Is there a possibility that these springs are worn out on a car that only has 20 k on it?
thanks
sammi
QuoteReply
njhyundaitech
post Jun 5 2008, 06:36 PM
Drives: 90 mustang
Status: OFFLINE
Spray the whole drum brake assembly with brake clean, spray the drum out, and lube the contact points of the shoes at the part of the shoe where it rubs against the backing plate. report back.
QuoteReply
Hyundaiownersclub
post Jun 6 2008, 06:27 PM
Drives: Tucson
Status: OFFLINE
QUOTE(Hyundaiownersclub @ Jan 2 2008, 12:38 AM)
Did anybody read this
QuoteReply
> Link To Us
> Similar Threads
2008 Elantra Alarm/anti-theft
Forum : 4G (2007+) Elantra
tchyundai 95 3 Today, 09:20 AM
By: tchyundai
Drum Brakes: 180mm Or 200mm?
Forum : 2G (2000-2005) Accent
sopclod 72 2 Today, 08:04 AM
By: sopclod
2001 I4
ptt 41 2 Today, 01:47 AM
By: lovemysantafe
Brakes Squeeling <1yr
Forum : 3G (2006+) Accent
g3mini 72 5 Yesterday, 10:09 PM
By: bulldog
Major Elantra Recall
jackBryant 1,304 26 Oct 11 2008, 10:51 PM
By: GTEEEOOOO
13th October 2008 - 10:25 AM
