> Lousy Am Radio Reception
configman
post Nov 13 2005, 08:37 PM
Group: Validating
Drives: 2001 XG300L
A friend of mine just had his Hyundai in for service and one of his complaints was the lousy radio reception. Of course when he went back to pick up the car they told him they could find nothing wrong. However he did manage to get this little tidbit of information from the service manager and that was in a month or two a service bulletin will be issued with a fix for the radios. I'll believe it when I see it.
Montego
post Nov 14 2005, 02:44 PM
Administrator
Group Icon
Group: Administrator
Status: Online
Drives: XG's (2001&2002)
please keep everyone informed about this, as this has been an issue with several members in the past
HUSKER
post Nov 19 2005, 05:15 PM
Drives: 2004 Hyundai XG350L
The Infinity sound system is a good one. Problem is most upscale sound systems today put all the money in FM reception. It's hard to get a system that has good AM reception. I have cured this by subscribing to Sirius radio and now I can listen to what I want with no commercials.
configman
post Nov 29 2005, 12:24 PM
Group: Validating
Drives: 2001 XG300L
Just left my Hyundai after having my fuel filter changed. I asked about the radio situation and I was told that the only model that will be covered in the service bulletin will be the Elantra. Fuel filter cost $130.00 to replace. Totally outrageous. My Acura Legend only cost $50 parts and labor.
jangroshan
post Dec 27 2005, 01:57 PM
Drives: 2005 Hyundai Elantra
GREAT! My 2005 Elantra's AM reception is so bad I've stopped listening. Can't wait to see what the service bulletin has to say about a fix....if anything.
tech1
post Dec 27 2005, 09:00 PM
Drives: 2003 Accent
Try this, tune into a station that should come in clearly. If the reception is bad, get in the back seat and lightly bang on the right side inner rear panel trim about halfway up. Behind this trim is the glass amp. If the reception improves remove the trim and clean and tighten all the conctions on the amp.
Attached File(s)
jangroshan
post Feb 1 2006, 10:37 AM
Would this solution refer to an antenna installed in the glass, as opposed to a "fixed" antenna on the exterior of the car? The Elantra's antenna is a "fixed" antenna, while the Santa Fe's is imbedded in the window.
configman
post Feb 2 2006, 08:52 PM
Group: Validating
Drives: 2001 XG300L
If you notice the new Santa Fe's antenna is a stub mounted on the roof.
jangroshan
post Feb 3 2006, 12:38 AM
My Santa Fe is a 2002. No, I didn't notice the antenna on the new one.
bobpear
post Feb 8 2006, 06:04 PM
Drives: 2002 Hyundai Sonata
A big gripe with the radio of my 2002 Sonata was when I start the car with the radio on AM, I get several seconds of loud static as the antenna rises. It's extremely annoying and, of course, the Hyundai dealer said there was no fix. However, I unintentionally solved the problem recently when I left the radio with antenna up in the carwash. The carwash rollerbrush bent the antenna so that it only recedes halfway when I turn off the car. Now when I start the car, the antenna is already halfway up and I get much less static on AM !!!!!!!
ahrma525
post Feb 21 2006, 10:31 AM
Post #11
Drives: honda's
Technical Service Bulletin Group
90 - Electrical
Number
01-90-005
Subject
Date
2001 XG 300 In-Glass Antenna Amplifier Weak AM Reception
05-2001
Model
XG 300 2001
2001 XG300 IN-GLASS ANTENNA AMPLIFIER WEAK AM RECEPTION
DESCRIPTION:
The rear window glass on the XG300 model contains specific AM/FM antenna grids. If the leads to the antenna amplifier from these grids are incorrectly reversed, the AM reception will be poor.
NOTE
The antenna amplifier is powered ONLY when the radio is on, it is NOT powered when the CD or Cassette player is in use.
NOTE
The antenna amplifier and the antenna grids in the rear window together form the "Diversity Antenna" as shown in the ETM under "Audio System".
NOTE
Right rear "C"pillar with interior trim panel removed.
DIAGNOSTIC PROCEDURE:
Make sure the radio turns on, and that it operates in the CD mode. Verify the customer's description of the condition may be duplicated, and that it is not present in another XG300 under the same conditions with the same model radio that operates properly.
Access the antenna amplifier by removing the RH 'C' pillar trim. First, loosen the door opening molding to get access to the back of the RH 'C' pillar trim, then carefully pop the clips out of the 'C' pillar. Work from the top clips to the bottom, then remove the RH 'C' pillar trim.
If the AM mode does not operate but the FM mode does, check the connections between the antenna amplifier and the rear window in-glass antennas. You MUST make sure the lead with the yellow tape is connected to the top grid.
If neither AM nor FM modes operate on the radio, check that the power and ground have at least 12V between them by using a test lamp when the radio is on in the AM or FM modes. Other checks include checking the integrity of the antenna feeder cable, and the connections between the antenna amplifier and the rear window in-glass antennas.
NOTE
The antenna lead is clipped to the antenna amplifier. Slide the antenna lead up, then slide the collar up to release the lead. See photo for sequence.
NOTE
When testing the antenna feeder cable integrity, be sure not to expand the female receptical at the rear of the vehicle. The resistance from end to end should not exceed 3 ohms; the resistance between the inner wire and the outer shielding wire should be infinite (greater than 1M ohms).
WARRANTY INFORMATION
Normal warranty procedures apply. Refer to the LTS manual for details.
jangroshan
post Mar 2 2006, 09:58 PM
Post #12
Progress ... however, we're still waiting for a fix for the 2005 Elantra AM radio reception. I haven't listened to my talk radio programs for months because of the horrible electrical interference that no one seems to be able to do anything about.
sylvesterstallio...
post Apr 23 2006, 05:51 PM
Post #13
Drives: 2004 hyundai Santa Fe
:amen: AM STATIC CURED ON 2004 HYUNDAI SANTA FE !!!!!!!!!!!!!!!!!!!!!!!!!!!
I CURED the AM static (noise that sounds like electronic interference) on my 2004 Hyundai Santa Fe. The "static" only started 2-3 months ago. I pulled each fuse out of the fuse box individually, waited a few seconds, and stuck it back in - one fuse pulled at a time mind you. After that, the "static", which actually sounds more like squirrely electronic sounds, was gone. I can give many more details if anyone desires.
jangroshan
post May 16 2006, 11:04 PM
Post #14
:banana: The service bulletin finally came through for fixing the lousy AM radio reception in my 2005 Elantra!! Had the car at the dealer for it's quarterly maintenance and just happened to ask if anything had come through yet, and surprise of surprises IT HAD! There is now a "static kit", FP No. 96140-2D00A. It's basically a noise filter and some kind of "padding" around the wiring that keeps the electrical interference under control, thus not affecting the quality of the AM reception. :clap: It's taken a year to to finally get this problem solved, but it finally is. Oh boy. Talk radio is back !!!
This post has been edited by jangroshan: May 16 2006, 11:10 PM
Robo
post May 17 2006, 12:01 AM
Post #15
Drives: 2006 Hyundai Sonata LX
Don't know if this is part of the issue, but a lot of after market tint has metalic particles in it and will interfere with am reception on window mounted antennas. This according to some tint installers. I had an 05 Elantra, unfortunately I never used the am radio so I can't say whether or not I had the problem. The fm worked great though!
This post has been edited by Robo: May 17 2006, 12:12 AM
jangroshan
post Jun 11 2006, 05:33 PM
Post #16
My 2005 Elantra doesn't have a window mounted antenna, so I don't think window tinting.....especially after-market which I also don't have.....was my problem.
iam4uf
post Nov 12 2009, 06:35 PM
Post #17
Drives: 2004 Sonata
I have a 2004 Sonata with poor AM reception. It has an electric antenna. Anyone know of a booster or a fix for the radio? Thanks
No New Posts Radio/cd Player
keep or replace
1 sotonscotty 18 Today, 09:01 AM
Last post by: Learn with Mike
No New Posts Radio Problems
18 Arion 908 16th March 2010 - 03:49 PM
Last post by: KDC
No New Posts Amp Location
1 marks 204 9th March 2010 - 04:34 PM
Last post by: Tech937
No New Posts Topic has attachmentsRadio Removal
Remove radio to fit Parrot kit
11 madan97 1,164 7th March 2010 - 02:49 PM
Last post by: Limestone-Cowboy
No New Posts Radio, Interior Lights, And Clock Do Not Work
0 mcochran 56 27th February 2010 - 06:09 PM
Last post by: mcochran
21st March 2010 - 11:05 AM
Privacy Statement
