two possible points, firstly as you pointed out is the engine imoblizer but it is unlikely that should suddenly go wrong, most common thing is the ignition stop switch fitted on the injector pump, when you switch off the ignition the power supply to the pump is stoped by this switch thus stopping the engine, when the ignition is switched on the switch allows fuel back into the pump. if you look at the injector pump you will see the switch which is about the size of a cotton reel with a wire attached to the top of it, if you remove this switch you will find a spring and plunger inside it, remove the spring and plunger and refit the switch, if the engine now starts then thats the problem (you will have to stall the engine to stop it)
