problem solved hi there I had the same problem engine was dificult to start when hot, used to cut off, when driving or idleling, sometimes it would not start for 20 minutes after turning off. so last summer i called the AA the guy had a look around and checked a few things, and said it could be the crankshaft sensor, then i took the car to hyundai and i asked them to connect to the computer, but it did not show a thing, but the problem did not come in that day and the car always started first time so they could not find, they said it could be immobilizer. 3 weeks a go i done a service and changed all filters, fuel filter as well, engine flashed etc, and i cleaned the crankshaft sensor, after all that the car got better, but still hard to start most of the time. after many months i decided to do what the AA man said and BINGO it was the crankshaft sensor £30 and its easy to change 10 mm spanner, and just connect the wire conector it is next to the gear box, : botton of engine good luck.
