Tried to search for other similar topics but I guess I didn't use the right word combos. '06 Sonata with 3.3 motor. When trans. shift lever is placed in Drive it will not automatically upshift out of 1st on its own. Dash trans. gear position display reads 'D1', not the normal 'D'. In Shiftronic mode it will occasionally upshift to 'D2', but no farther, and does not always do that in this mode. But...if I leave the shifter in the 'D' position I can get it to upshift by then moving the shift lever into Neutral and then back down to Drive. The trans. upshifts and the dash display changes from D1 to D3. Do this again and it upshifts/displays D4. Only after reaching a bit over 40mph can I get it to upshift/display D5 and all seems normal at cruising speed. Trans. will downshift normally.
This problem occurred about 2 1/2 years ago, but only once or twice, then everything was OK. Dealer could not find any problem at that time. Last week I had it into the dealer for a 'check engine' light problem. At that time they replaced the 'Inhibitor Mode Switch', whatever that is. As it seems too coincidental I'm wondering if this may be related to this previous "fix". Only info I could find at all close to my problem was TSB # 06-40-013 which deals with a similar, but not identical, problem with the transaxle.
Probably back to the dealer tomorrow. We'll see what happens.
This post has been edited by dsgrntldPW: Feb 5 2010, 03:07 AM
