I know this is common maintenance, but I was changing the oil yesterday and I decided to take a look at the air intake, right at the butterfly. I was surprised to see how much crud had accumulated around the opening!
Some throttle body cleaner and a good rag did the trick!
Though it ran fine, it now idles more smoothly and is more responsive at low rpms.
All I did was...
-loosen the hex screw that clamps the intake snorkel to the throttle body. This is a black 10mm screw with a phillips center.
Number of downloads: 133-release the air filter hold down clamps (3).
-pull the intake snorkel off of the throttle body intake.
Number of downloads: 110The butterfly will now be staring right at you.
Number of downloads: 101I used throttle body cleaner (as opposed to carb cleaner) so there was no chance of boogering up the positioner. Also, I sprayed a clean rag (old tee-shirt!) and wiped it clean while holding the butterfly open. This way none of the dissolved gunk would go into the intake.
Additionally, while I was in there, I cleaned the Mass Air Flow Sensor. This is located directly between the air filter chamber and the Throttle Body.
To get at this, loosen the 10 mm hex screw that clamps the unit to the air snorkel.
Number of downloads: 88Then, using MAF Sensor Cleaner only (otherwise you may strip the coating off the heater wires), spray the heater wires and surrounding assembly till clean.
**Remember, these are heating elements that register airflow by the amount of current it takes to maintain temp as air passes over them.
Do not touch them with anything, do not clean while energized, and allow to dry before you turn on the ignition or you will damage the unit.**
Number of downloads: 86You may also want to spray the honeycomb opening of the MAF Sensor from the air cleaner side to be sure it's clean as well, for proper air flow.
Number of downloads: 71Once everything is cleaned, allow to dry and reassemble. Be sure not to over tighten the hex bolts or they will strip.
Don't be surprised if its hard to start at first due to residue or fumes left in the intake. Once she fires up, it will purr like a kitten, start easier, and have better acceleration from idle! Gas mileage should improve as well! (IMG:
style_emoticons/default/thumbsup.gif)
Go get 'em!
This post has been edited by ThunderLizard: Jan 21 2010, 06:12 PM
