QUOTE (cjelbueno @ Jan 10 2010, 10:19 PM)
hi all
these are the codes that come up
p0715: input/turbine speed sensor malfunction
p1191: ETS limp home valve on(i looked this definition up online as report stated "manufacturer specific code")
P0306: misfire detected (cylinder 6)
p1159: variable induction system(i looked this definition up online as report stated "manufacturer specific code")
p1193: ETS limp home-low rpm(i looked this definition up online as report stated "manufacturer specific code")
the car will drive fine at times but sometimes ill b driving and my car will jolt suddenly and the rpm will suddenly go up.
then once i come to a stop the car wont accelerate, well i does but itll accelerate very slowly with no power till it gets up to about 30 mph.
it apparantly gets stuck in third gear and wont go down nor up. so what i do is manually bring it down to second as it wont go to first and then once it has
gained speed ill bring it back to third. i dont kno what to do as this problem isnt persistent. furthermore sometimes the cel will actually turn off and
the car will run perfectly. any help will surely b apreciated.
Change your plugs and wires. I just went through very similar symptoms and months of irritation. I finally took it to the dealer, bought the NGK plugs and new wires from the dealer ($110 total) and switched them out in 2 hours. It's a pain in the A$$ but it's the cheapest thing to fix (although it's $350 at the dealer to get them to do it). You'll find step by step instructions on here, sorry I don't have the link.
Hope this helps and let us know how it goes!
mike
