Radio Problems |
Jan 10 2010, 07:13 AM
Status:
Drives: 2009 Hyundai i20 1.2
I got my car yesterday to the Hyundai Service and they also supported what you said about the "common problem". The thing with the fuse didn't work out, but they did something else. They disconnected the battery from the car for about 5 seconds and then connected it back and it worked.
The problem why this happens is because most probably everyone of use when they turn of their engine, they don't turn off the radio and so it Crashes. It is also written in the book that before turning off the engine you should turn off the radio.
Anyway, nice that is fixed now. If it happens to anyone, try the fuse or to disconnect the battery.
Jan 17 2010, 11:14 AM
Status:
Well i don't know about Hyundai if it is a permanent problem or what but i guess we have to be a bit more careful with that one (IMG: style_emoticons/default/smile.gif)
Jan 23 2010, 02:16 PM
Status:
Drives: 2009 Hyundai i20 Asta 1.2
If you have an older software version HU this may happen . To check the software version of your HU first press and hold 1FF button then 6 of the HU. Look at the Multi information Display which displays your Trip A, Trip B etc . If the code is VER M08 S69 D18 then your HU is faulty and you can ask for a free replacement . If the code is VER M08 S71 D29 then your HU is alright.
This post has been edited by i20 Asta: Jan 23 2010, 02:18 PM
Jan 23 2010, 06:54 PM
Status:
Drives: i10 1.25 style oyster grey ESP
QUOTE (i20 Asta @ Jan 23 2010, 07:16 PM)  If you have an older software version HU this may happen . To check the software version of your HU first press and hold 1FF button then 6 of the HU. Look at the Multi information Display which displays your Trip A, Trip B etc . If the code is VER M08 S69 D18 then your HU is faulty and you can ask for a free replacement . If the code is VER M08 S71 D29 then your HU is alright. hi i20 Asta dose this apply to all pa710rds radios ie the radio in the i10 ? and if so what codes firmware version applies many thanks in advance TOODEN .
Jan 23 2010, 10:43 PM
Status:
its for the i20's .
is the i10 also having the same problem? both using same HU.
Jan 25 2010, 12:48 PM
Status:
Drives: 2008 Hyundai i10 1.2 Comfort, 2005 Hyundai Getz 1.4 GSi
I cured all the OEM radio problems at a stroke by replacing the radio. Now I have a Sony 'double din' one which gives me USB, aux in, a decent radio and cost me under £200 including fascia kit, connectors etc. It also has a CD player as does the OEM radio, but since I now just plug in a flash memory to the USB, I don't need the CD player. The best that can be said about the OEM radio is that it's "cheap and cheerful",- you can't really expect a decent unit for the price of the car, especially when you consider the other standard equipment compared to other car manufacturers offerings! LC.
Feb 4 2010, 04:07 AM
Status:
Drives: Hyundai i20
I've have the same problem with my i20's radio. I have managed to reproduce the problem, and it happens every time I try to eject a CD from the radio while the car is off (key removed from ignition). Easy solution, don't try and eject disks while the car is turned off. (IMG: style_emoticons/default/tongue.gif) But a quick fix for it is to remove the fuse holder that holds the ROOM and AUDIO fuses... In my i20 its the top most set of fuses in the fuse box inside the car. After unplugging them for a minute or so, plug them back in and it works again.
Feb 7 2010, 08:17 AM
Status:
Drives: 2010 i20 comfort 1.4 in dark grey
QUOTE (i20 Asta @ Jan 23 2010, 03:16 PM)  If you have an older software version HU this may happen . To check the software version of your HU first press and hold 1FF button then 6 of the HU. Look at the Multi information Display which displays your Trip A, Trip B etc . If the code is VER M08 S69 D18 then your HU is faulty and you can ask for a free replacement . If the code is VER M08 S71 D29 then your HU is alright. I did as you said, press and hold 1FF then 6 and the display never changed! Am I doing something wrong? Not that I have any radio problems but thought I'd just check which version I had.
Feb 8 2010, 01:33 PM
Status:
Drives: 2009 Hyundia i20 1.2
Hi i20 Asta
trust mine to be different, I did as you sugested and got the code M08 S69 D27
is that a dodgy radio or is it OK?
The car is a i20 comfort 3 door, September 2009.
Thanks for the good advice
Regards Richard
Forgot to add, so far the radio has been fine except it seems to spend a lot of time hunting for the station it is tuned into. Thanks.
This post has been edited by Richard Brown: Feb 8 2010, 01:36 PM
Mar 16 2010, 03:46 PM
Status:
Drives: Hyundai i20
Good to know some people care I bought my i 20 on 6 March 2010 7 days on radio problem I.E no sound from speakers radio looks to be working Book in for next monday 22 will let you know result. Hope i bought the right car.
Similar Topics
Similar Topics
