QUOTE (jsinton @ Nov 22 2009, 02:02 PM)
No, it means there is no codes. Unless you got an error message about "no connection".
Ok, then the CEL system failed you. If you obviously don't have any spark in ANY cylinder, then I'd be replacing the crank position sensor. Since we don't have the 1.3L motor in the US, I can't be sure about the sensor location, but on the 1.5 motor it's near the flywheel and comes out easy.
many thanks, will check this out tomorrow and let you know if that is it. l have been told that they are a known failure item.
