 Hyundai-Forums.com > Hyundai Models > i10 Forum
> Condensation, Only Me??
bluewire
post Nov 20 2009, 05:47 PM
Drives: i10
My i10 suffers from bad condensation when parked up.
I came out of work today to find the windscreen heavily condensated over.
I took a look at all of the other cars and mine was the only one.
what could be causing this?
Cardiff Noddy
post Nov 21 2009, 06:52 AM
Drives: 2009 Hyundai i10 Classic
Yeah, I have the same problem. Mists up real easy and like you said looking around at other cars in the street the i10 appears to be the only misted up? Any ideas?
Vectis
post Nov 21 2009, 09:58 AM
Drives: Landrover
Getting in the car with a wet coat on will introduce moisture into the car leading to condensation but the air con should take it out.
Learn with Mike
post Nov 21 2009, 02:55 PM
Drives: Blue '59' plate i10 comfort
are you talking about the inside or outside of the window misting?
Cardiff Noddy
post Nov 21 2009, 05:06 PM
Inside for me.
talkalot
post Nov 21 2009, 06:02 PM
Drives: I10 Style 1.2
Talking of condensation but slightly of topic I washed my I10 in the damp for the first time a few day ago. I was very surprised to find the drivers side headlight all steamed up on the inside. Only the drivers side. I was wondering if the damp had got in to it some how ? Has this happened to any one else ?
bluewire
post Nov 22 2009, 04:13 AM
Drives: i10
Inside for me
geo ger
post Nov 22 2009, 04:49 AM
Drives: i10classic 09 1.2
inside i10 mists too ,have seen other i10 misted inside
Badly Drawn Roy
post Nov 22 2009, 06:42 AM
Drives: i10 Classic 1.2
QUOTE (talkalot @ Nov 21 2009, 07:02 PM) *
Me to, drivers side only.
BDR
mobile
post Nov 22 2009, 05:47 PM
Drives: i10
I have not really noticed anything to bad, although once I had really bad condensation on the inside windscreen..with dripping down the window... it was only there for about 3 1/2 hours, but it had not done it before or since.
scm
post Nov 23 2009, 02:34 AM
Post #11
Drives: Toyota and i10
The condensation can be bad especially if you bought your car in the winter. It was parked for quite a long time and it has got dump inside. Simple solution:
A\C on for max heat and leave it for some time. If it still getting wet then check carpets, under the carpets and boot under the spare wheel if there is no water. Check the cabin filter if it is not wet. Even if you open your door during the rain that should not be an issue.
This post has been edited by scm: Nov 23 2009, 02:35 AM
Duuncan
post Dec 10 2009, 08:19 AM
Post #12
Drives: 2009 Hyundai i10 Style (59-Plate)
Just thought i'd drag this back to the top as today my didn't want to clear, no amount of air-con and heater would clear it fully, rear offisde window especially bad, when I opened the door to look for damp the sill was very wet, dried it and all is fine now
firegarder
post Dec 10 2009, 01:43 PM
Post #13
Drives: 2009 hyundai i10 1.2
I've also had a problem with this appearing every day, which I really don't want when I'm leaving for work really early in the morning.
I got my car at the end of the summer, I take out my umbrella or coat if they are wet, not noticed any damp spots, but will have a closer look. I've had the air con on with the heater as I travel in. Maybe I've not had them on long enough? But when its gone, there does come a point where I can't stand anymore heat. lol
Dunno what else to do, I like my sleep, I don't want to have to get up at 5:30am to demist my car! And its going to start turning to ice when it really gets cold. (IMG:style_emoticons/default/sad.gif)
This post has been edited by firegarder: Dec 10 2009, 01:45 PM
Learn with Mike
post Dec 11 2009, 03:08 AM
Post #14
the air-con can be a great help at demisting, but what happens to the cold surface?
condensation, what happens when the air-con is switched off?
the condensation moves into the car.
i find if i need to use the air-con to clear the windows, i will have to keep it on all day or the windows mist up again.
use the heater, as hot as you can bear, fan on 3 or 4 and if not raining open the rear windows a little to improve ventilation.
another idea is the wind deflectors, which mean the windows can stay open longer.
ianwayne
post Dec 11 2009, 04:53 AM
Post #15
Drives: 2002 Astra Dti, 2009 Hyundai i10 1.2
As a heavy user of an i10, your experiences would be valuable as feedback.. if they take any notice.
Does it make any difference if you have the air on 're-circ?' In the summer, this keeps the cold air in the car but I would have thought you need fresh air entering the car for the damp air to be expelled.
tomhyundai
post Dec 11 2009, 12:41 PM
Post #16
Drives: iLoad
QUOTE (ianwayne @ Dec 11 2009, 09:53 AM) *
I had this on mine - and it was because I'd hit the recirc button by mistake. Switched it off and with the A/C on it cleared within about 30 seconds.
As regards the condensation on the headlamps, it mentions it in the handbook. Switch the lights on and it disappears pretty quickly as they warm up.
firegarder
post Dec 13 2009, 07:06 PM
Post #17
Funily enough after posting this, the condensation had disappeared! lol I had had the windows open after the heating for a couple of days in a row, that seems to have sorted it.
loobey
post Dec 15 2009, 12:55 PM
Post #18
Drives: 2009 Hyundai i10ES
My windows have had terrible condensation for the past couple of weeks - the other morning this had frozen on the inside of the windscreen and took ages to clear. However I have started removing the cloth I use to wipe the screen from the car (I either put it on the radiator at work or home) and hey presto this has resolved the problem. I also make sure my wet umbrella is removed from the car.
To clear the windows I put on the air-con, full heat, air circulation button OFF, and full blast on the fan and this clears in a couple of minutes. Certainly quicker than my non-air con Ford Ka!
So one problem resolved - squeaky seatbelts remain!! (IMG:style_emoticons/default/rant2.gif)
No New Posts Condensation Problems
condensation problems
3 harryval 213 4th February 2010 - 02:06 PM
Last post by: bizzay1
No New Posts Condensation Inside The Car
8 Docproc 553 7th January 2010 - 02:20 AM
Last post by: DjCivic
No New Posts Water Condensation On Windows
4 Tiger_i10 539 6th May 2009 - 10:14 PM
Last post by: accent sport
No New Posts Condensation In Tails?
12 ewing 328 24th July 2008 - 10:13 PM
Last post by: LilBean
No New Posts Condensation In Speedometer
4 t2t2 173 13th December 2007 - 01:04 PM
Last post by: t2t2
20th March 2010 - 12:10 PM
Privacy Statement
