Help Please...noisy Lifters |
Nov 19 2009, 07:20 PM
Status:
Drives: 2007 Santa Fe, 2001 Accent GSI
QUOTE (beware @ Nov 19 2009, 05:27 PM)  hello,
Aparently I have a posible problem with me engine ( 2,7 L, v6, 9500Km ). If I leave the Santy outside..in the morning my lifters make noise for about 2 minutes..after they go smooth..no noise at all. If I park the Santy in my garage (warmed one)..in the morning I have no noise at all. I run Castrol Synth since 2000km on the engine. Is this normal or I have to worry about. What I want to point is that this lifter noise is directly proportional with the outside temp.....if cold ( minus4 centigrade..noise for about 2 minutes..if between 5 - 10 centigrade...noise for about 1 minute....more than 12 centigrade..no noise . I just want to know the normality of this problem or if is something common with this type of engine.
thanks indeed
Mario I had a problem with the 3.3 on our SF that I swore was noisy lifters - they got noisier with time. I took it into the dealership (under warranty) and they changed the timing chain idler - no more noise.
Nov 20 2009, 05:58 AM
Status:
Drives: 2008 Santa Fe 3.3 AWD
When you changed the oil, did you use an aftermarket filter? If so, it might not have an anti-drainback valve. I'd replace it ASAP with one that does, preferably a Hyundai brand. If your engine gets damaged by an aftermarket filter that does not meet Hyundai's spec, you're outta luck with the warranty.
Beyond that, some degree of clattering on cold starts is normal, and not a cause for alarm if it goes away within a minute or two.
Nov 20 2009, 12:35 PM
Status:
Drives: 2009 Hyundai Santa Fe Limited
I don't believe it is the oil or the oil filter.
In my experience it is the gasoline, especially Shell (with Ethanol).
When I switched to, say Esso, I did not experience the lifter noise any longer, even at startups during cold weather.
Nov 21 2009, 11:59 AM
Expert
Status:
Drives: 2007 Veracruz Limited
QUOTE (beware @ Nov 19 2009, 04:27 PM)  hello,
thanks indeed
Mario First off, you need to identify the noise a bit more closely. Not all underhood noise that sounds repetitive is caused by lifters. If it were the lifters, the noise will be typically a faint tick-tick-tick sound. Valve actuation parts are small, and small parts make small noises. You will probably not hear it at all if the hood is closed and you standing 15ft away. If OTOH the sound is more like a knock-knock-knock and loud enough for you to hear it sitting in the car, it is definitely not the lifters. It is probably caused by some other rotating device that is affected by the low temp. It could be a stiff belt that - once warmed up - becomes more compliant and so goes around the various pulleys smoother without making noise. Next time, open the hood and stand right next to it and have some one else start the car. Try to see if you can hear what area the noise is coming from.
Nov 21 2009, 03:15 PM
Group: Super Mod
Status:
Drives: '04 Santa Fe GLS 4WD (Born 5.24.04)
QUOTE (PoMansAWD @ Nov 21 2009, 11:07 AM)  All gasoline is "up to 10% ethanol" in the States now per the Federal Gubment (thank you very much). You can't buy 100% gasoline now. Not sure how that effected you, but S. Ontario is real close to me.
Joel Don't get me started on that crap. I was averaging 20 mpg in mixed driving before they mandated that B.S. and now I struggle to pass 18 mpg in the same conditions. Great way to reduce dependence on foreign oil; use MORE of it.
Nov 22 2009, 12:42 AM
Expert
Status:
QUOTE (beware @ Nov 21 2009, 07:07 PM)  Now I use 5W30 synth oil. The heard sound is a loud ticking specific to lifters ..in other words I feel it like a <lack of oil> between the camshaft lobe and lifter. Sincerely I didn,t hear all my life how is the injector noise ..but this noise turns more and more muffled (it changes the tonality) until it stops after 2 minutes .. Yes I started the engine in the morning and poped the hood immediately and the noise is not so strong ( like it is sitting in the car).but it comes from the near the firewall bank of cylinders..and a bit from the front one. After two minutes the noise is stopped and the engine is super smooth . As of the gasoline ..no result ..fueled up yesterday ..and no modification this morning ..the same noise.I was thinking of mixing a little amount of two stroke engine oil in the gas ..lets say 150 cc for the tank ...just to add a little lubricity to that ethanol gas...don,t know..i,ll see. In my youth I use to run my engine with 100% methanol and it was a charm( modified jets in the carburetor) ...the difference was the consumption...a bit higher ..but the methylic alcohol prices were well down and the start up in the morning ..bit lasy. Well, thanks again for your time guys
Mario If any part of your engine is lackcing oil for as long as you described, your engine would have been toast long before you had a chance to post questions in these forums. It really is best if you don't jump to conclusions. I would strongly recomend you DON'T put 2-stroke oil in your gas tank, unless you know exactly how that would affect your emission control equipment (cat converter, O2 sensors, etc.). Besides, the typical mix ratio for these oils is 25:1 to 50:1. Gas engines are very popular these days for RC airplane applications. Guys are flying 50cc singles to 150cc twins. Some of the competition flyers use specialized synthetic 2stroke oils that go as high as 100:1. Your putting 150cc worth of 2stroke oil in a 20gal tank is more than 500:1. I doubt your engine will feel it at all. Billions of miles have been driven on 10% ethanol in the past 10yrs or more. Why would your engine NOT be able to cope with it? Extreme cold temp start is admittedly one of the harshest things your engine will endure, but it is hardly detrimental. Invest in an engine block heater if you must, but stay away from the snake oil remedies. BTW, why the 5w30? The filler cap clearly states 5w20. If you must try something else for the cold winters, 0w20 would be more the ticket, no?
Similar Topics
Similar Topics
