QUOTE (westpennsam @ Nov 17 2009, 07:01 PM)
I guarantee that you have some bent valves. Same thing happened to our 01 about 3 months ago and it bent all 4 exhaust valves. Like montego said, all you can do is put the new belt on and see if any cylinders have compression. Removing the cylinder head on this engine is not bad at all. Just to give you an idea, we had just under 500 bucks in the whole job doing it ourselves. You will have about 400 in the machine work and the gasket kit. I also put a water pump and a new timing belt tensioner in also. The hardest part we had was getting the crank pulley nut loose, and some of the intake manifold bolts are a little hard to get to. If you like to do your own work this is really not that bad of a job. Plus, it will save you alot of money. We are always here to help if you run into any trouble.
Yea, unless all the valves were closed when the belt broke...you bent something.
I have to agree with cheenu. A scope should let you see where the valve hit the piston. I would think a steel valve would leave a mark in an aluminum piston.
