The cruise control buttons on the '01 - '06 models were never illuminated, one of my biggest pet peeves about the car. Thankfully, there are only four buttons and they have a tactile barrier between them so once you learn which is which, you can operate them at night without thinking about it.
As for the PRND shifter lights, that is a fairly difficult task that requires some dexterity. Here is a step-by-step for you, should you choose to take this on. The bulbs come with a blue sleeve to match the rest of the interior so you'll have to get the bulbs ahead of time. They are a 194 so you can get it from the dealer or NAPA will likely carry one with the blue sleeve.
You'll need one short and one standard-length Phillips head screwdriver and preferably a dry surface on which to kneel while doing this.'
- Slide driver seat back all the way and crank front of bottom cushion up.
- Locate three screws on the side of the center console (1 up front, 2 in the back)
- Remove these screws and set them aside (cup holder works great), then remove the plastic panel alongside the console.
- Look at the shifter mechanism and you will see a metal bracket that rolls over a series of detents to give resistance in between gears. There is a small Phillips head screw holding this on. Use the screwdriver to back the screw off then loosen it the rest of the way by hand.
- Remove the detent bracket. You will have to do this in order to provide enough clearance to remove the bulb socket. It's a PITA but the only way it can get done.
- Right below the R and N lights, you will see a pair of wires running up to a socket. Turn this socket and it will pop right out.
- Replacing the bulb is as easy as sliding out the old one and popping in the new.
- Getting it back in is not as simple. I recommend turning the lights on to test the new one and as a light source to help you guide the socket back into the plate.
- Don't panic if the new bulb flickers while you are maneuvering it into position. The wiring in there is a bit finicky and it doesn't indicate any fault with the bulb.
- Re-fit the detent bracket to the shifter mechanism and tighten the screw down. Before re-fitting the console side cover, make sure you can shift from Park to Drive and into Shiftronic and that the detent bracket stays put.
- Slide the console cover back on and screw it down.
Good luck! (IMG:
style_emoticons/default/thumbsup.gif)
