Can't Remove This Screw! |
Nov 17 2009, 09:50 AM
Status:
Drives: 2009 Hyundai Santa Fe Limited
Hi everyone. I purchased some LED lights to replace the stock license plate lights. Unscrewed the first light housing easily...there's only 2 phillips screws per housing. Installed the LED light. Looks great! Moved onto the second light housing. Unscrewed the first phillips screw. No problem. Started to unscrew the second phillips screw and the darn thing just turns and turns and won't come out! Arg!! (IMG: style_emoticons/default/rant2.gif) Any ideas or suggestions?
Nov 17 2009, 11:56 AM
Status:
QUOTE (IndyMGA @ Nov 17 2009, 11:37 AM)  There are a few versions of screw-starters which may help you. Some have springy hooks on each side of the blade to grip the screw, some have expanding points (but that may just be for flat-head).
Are the threads stripped or is the socket spinning inside? Thanks for the reply. I don't think the thread is stripped, as I was able to tighten it back up again. The socket seems to be spinning inside...meaning that I can feel the screw move down and then it pops back up again. If I can find one of those screw-starters with the springy hooks on each side, that should do the trick. I just need something to grab the head of the screw so that I can try and pull it down. Any idea where to find a screw-starter springy-thingy? Thanks.
Nov 17 2009, 02:03 PM
Status:
This is the tool that I had in mind... http://www.generaltools.com/Products/Mini-...ickup__388.aspxNow to find a store here in the Mississauga GTA area. Fellow GTA'rs, any suggestions on where to find this tool? Thanks.
Nov 18 2009, 06:09 AM
Status:
Drives: Santa Fe 2009 GLS
When unscrewing, place a small pair of cutting plyers behind the head of the screw and pry it towards you to put pressure on the lock that is in the back...That should do the trick..
Carl
Nov 18 2009, 08:39 AM
Status:
Drives: 2009 Santa Fe GL AWD
QUOTE (radar2000 @ Nov 17 2009, 03:03 PM)  This is the tool that I had in mind... http://www.generaltools.com/Products/Mini-...ickup__388.aspxNow to find a store here in the Mississauga GTA area. Fellow GTA'rs, any suggestions on where to find this tool? Thanks. Try Princess Auto in Missisauga. They should have what you're looking for.
Nov 18 2009, 02:47 PM
Status:
QUOTE (radar2000 @ Nov 18 2009, 09:11 AM)  Thanks for the replies everyone.
I tried the old small flat-head behind the head trick, but the light housings hole wouldn't allow for much room.
I'm a couple a minutes from Princess Auto...I'll take a drive there this afternoon and will have a look.
I'll keep you posted on my progress.
Cheers! Princess Auto did not have this hand tool (IMG: style_emoticons/default/sad.gif) I did buy some various tweezers that seem to have a good gripping design. It cost my $3 bucks. If it works, great. If it doesn't...oh well.
This post has been edited by radar2000: Nov 20 2009, 03:32 PM
Nov 19 2009, 06:19 PM
Status:
Drives: 2007 Santa Fe, 2001 Accent GSI
QUOTE (radar2000 @ Nov 18 2009, 02:47 PM)  Princess Auto did not have this hand tool (IMG: style_emoticons/default/sad.gif) I did buy some various tweezers that some to have a good gripping design. It cost my $3 bucks. If it works, great. If it doesn't...oh well. I have one of those screwdrivers with the springs on the head & don't use it that much. I find that magnetic ones are more convenient (unless I'm using a non-steel screw). If you get one of them, you'll find that the spring "grapples" aren't strong enough to pull with - they're really only made for holding the screw against the screw driver so that it won't fall off as you're trying to start it. Posting a picture of the location (and screw) might give you some better advise, but so far the knife blade or the side cutters behind the head get my vote.
Nov 20 2009, 03:38 PM
Status:
QUOTE (radar2000 @ Nov 20 2009, 03:29 PM)  Tweezer kit = epic fail...
I tried the flat head trick again and it still won't budge.
I think my only alternative is to take it in to Hyundai and have it changed/serviced under warranty...sigh. With it under warranty, that's exactly what I'd do.
Similar Topics
Similar Topics
