Hi Everyone, I just got my 2001 AWD and found that the driver side rear running light doesn't work. I have changed the bulb with a 1157 with no success, the rear passenger side running light works fine. The brake lights also work fine when the brake is depressed. I have a tester and I get no power at the socket. Today I took apart the rear panel to check the connection and there is no power there. I proceeded to take apart the front fuse area as the fuse was not burned out. I used my tester at the fuse box and I did get power there but I am not sure if the brake lights also got thru that fuse. I am not sure what to look for next as I don't have the wiring diagram. Any help would be greatly appreciated as I will end up at the dealership if I can't find out where the problem originates.
