> Trans Fluid Change At 105k Miles!?, `08 Sonata Manual
AustinJeff
post Nov 12 2009, 05:14 PM
Drives: 2008 Hyundai Sonata GLS
My owners manual tells me to change my "Automatic Transaxle Oil" at 105k miles. Am I reading this right?
MiamiLX
post Nov 12 2009, 05:57 PM
Hyundai Challenged
Drives: Sonata 2006 LX V6
QUOTE (AustinJeff @ Nov 12 2009, 02:14 PM) *
You are reading it right, but it is wrong. I need to have mine done at 30,000 miles because I am in a severe area. Are you?
Attached File(s)
boehmb
post Nov 12 2009, 07:05 PM
Drives: 2008 Hyundai Sonata Limited V6
I'll be changing mine at 30,000 miles. I've done this on every car I've owned and have never had a transmission problem. Shift quality even stays the same after 100,000 miles with frequent trans. fluid changes. I've owned GM, several Toyotas, a Subaru (current wife's ride has 100,000 miles on it and shifts like new), and now the Hyundai. I never went with the flush, only the drain-and-refill.
AustinJeff
post Nov 13 2009, 02:25 PM
I live in Austin, TX so I'd say that is severe usage for about 3 months due to the intense heat. I think I'll change it every 30k miles just to be safe. I bought it with 36k and I have no idea if it was ever changed. It just hit 40k, so I'll do it this weekend. Thanks!
ddix1026
post Nov 15 2009, 08:53 AM
Lonely Commuter
Drives: 06 Sonata GLS-V6 (mine), 07 Tucson SE-V6 (wife's)
even if you dont live in, or drive in, "severe" conditions, it is a good idea to change it out long before 105k miles.. i, personally, am almost the very definition of "normal driving conditions" (all highway, cruise control, little to no stop & go, not highly extreme temps) and even I changed mine out before that (I did around 60k miles)..
if you wait to 105k, plan on never doing it
AustinJeff
post Nov 16 2009, 02:52 PM
Thanks for all of your input.
I went ahead and changed the oil and the trans fluid this weekend. It was so easy! I have done this on several other cars and I have never done it so quicly or easily. I barely had to jack the car up at all. Hyundai really thought of the mechanic or DIYer when they setup this car. Nice job.
delhiboy3732
post Nov 17 2009, 05:14 AM
Drives: 2007 Hyundai Sonata l4
QUOTE (AustinJeff @ Nov 16 2009, 11:52 AM) *
Great, what kind of oil did you use?
AustinJeff
post Nov 17 2009, 11:01 AM
I went with the Walmart Super Tech Synthetic Oil and the Super Tech Trans Fluid too.
wymi
post Nov 17 2009, 12:44 PM
Expert
Group Icon
Group: Moderator
Status: Online
Drives: Mine: 2009 Santa Fe Limited Her's: 2007 Sonata GLS I4
QUOTE (AustinJeff @ Nov 17 2009, 11:01 AM) *
Is the Super Tech Trans oil you used rated for use in a Hyundai as an SPIII Trans oil?
This post has been edited by wymi: Nov 17 2009, 12:44 PM
Sequoiasoon
post Nov 17 2009, 03:29 PM
Expert
Drives: 2007 Sonata GLS 2.4L 5 Speed Manual
The whole title had me screwed up.
I read it as he as '08 manual (5 speed) which is available in the GLS (like mine). The 5 speeds call for GL3 75W90 gear lube (iirc) and not auto tranny fluid.
I HAVE seen some manual transmission cars that did require auto tranny fluid also as the lube.
rallyman
post Nov 18 2009, 09:39 AM
Post #11
Drives: 2006 Hyundai Sonata GL V6 3.3 Build date: Feb. 24, 2006
I'm with you, I'm confused too. I think maybe the OP was trying to say his 08 Sonata owner's manual called for a transmission fluid change at 105,000 miles. I hope that is the case because if he put auto trans. fluid in the manual trans. he better get that out of there and replace it with the proper gear oil ASAP.
AustinJeff
post Nov 18 2009, 10:54 AM
Post #12
Sorry for the confusion. I do have an `08 Sonata 4-cyl automatic. I did a simple drain and fill of the auto transmission fluid using the Super Tech transmission fluid. I read the comment below on another site. The comment is from the makers of Super Tech ATF:
"The proper Super Tech product is the Multi-Vehicle ATF. According to our additive supplier, Super Tech Multi-Vehicle ATF is ‘suitable for use” for the SP3 specification."
If I did something wrong, please let me know!!!! I have about 100 miles on it now and it seems fine. Shifts smoothly and no strange noises or slipping.
rallyman
post Nov 18 2009, 01:53 PM
Post #13
I don't think you did anything wrong. As long as the manufacturer states that it meets the SP III specification then it should be fine. I would be a little concerned if it doesn't actually state that right on the bottle though or at least on a written specification for the ATF.
MiamiLX
post Nov 18 2009, 02:10 PM
Post #14
Hyundai Challenged
This comes from another Forum that mentions us! (IMG:style_emoticons/default/thumbsup.gif)
I sent Warren Distribution an e-mail for additional clarification. See response below.
The fluid is “not” approved by Hyundai but is “suitable for use”. Our additive supplier, Lubrizol, does the test work and recommendations for their formulations and additives we use. When a fluid’s characteristics and additive technology are consistent to the OEM product, our additive supplier makes a recommendation, “suitable for use” as to what transmissions a certain product can be used in. We do have licensed Super Tech products; Dexron VI, ATF+4 and Mercon V. The other ATF products are not licensed but our additive supplier has completed test work on the formulations and has made recommendations as to what transmissions they can be used in. The specification sheet doesn’t really cover individual transmission applications but gives a general overview as to the vehicle manufacturer that it covers so SPIII wasn’t an oversight omission. A few years ago, you could cover the entire market with three ATF fluids. Since then vehicle manufacturers have inundated the market with different transmissions and thus the increase in transmissions fluids to meet certain applications. The Multi-Vehicle ATF was designed as a true multipurpose fluid for accounts that wanted to cover the majority of the ATF market with a few fluids versus a fluid for each particular transmission which would be almost impossible to accomplish. I checked some of the major brand fluids and they also list their Multi-Vehicle fluids as “recommended for” or “suitable for use” claims similar to the Super Tech product. I hope this expanded explanation helps in explaining the fluid.
dronrs
post Nov 19 2009, 08:51 AM
Post #15
Drives: 2006 Hyundai Azera Limited, Sonata LX 6
QUOTE (MiamiLX @ Nov 18 2009, 02:10 PM) *
All I see are comments regarding mileage, but no mention of time interval. My 06 Sonata LX6 has just over 13,500 miles on it. The fluid is still reddish in color and odorless even though the car will be 4 yrs. old in January. My service writer had "suggested" that I do a flush, but when I found fault with his suggestion he backed off and admitted that were I to have a problem with the tranny it would still be under warranty. What gives? Is it mileage and or time interval? I changed the ATF on my 06 Azera with 26,000 miles. That car is just 3 years old. Oh, by the way, service writer said the fluids deteriorate with age. Any comments would be appreciated. (IMG:style_emoticons/default/liebe011.gif) Don
rallyman
post Nov 19 2009, 01:50 PM
Post #16
In the owner's manual under Scheduled Maintenance it says "Where both mileage and time are shown, the frequency of service is determined by whichever occurs first.". For the automatic transaxle fluid it requires an inspection every 15,000 miles or 12 months with replacement at 105,000 miles or 84 months.
Under the Severe Usage Conditions it calls for the fluid to be replaced every 30,000 miles and no time is given. If you are driving under the severe conditions and I would imagine many of us are then every 30,000 miles should do it but in any event I wouldn't exceed the 84 months.
6speed8
post Nov 24 2009, 09:10 PM
Post #17
Drives: 2008 Sonata 2.4
So the trans service is pretty much a "drain & fill," not a filter also ?
rallyman
post Nov 24 2009, 09:30 PM
Post #18
That is correct. No filter replacement is required.
MiamiLX
post Nov 24 2009, 10:10 PM
Post #19
Hyundai Challenged
QUOTE (rallyman @ Nov 24 2009, 06:30 PM) *
According to V33, OMG you are wrong. I think he is wrong (IMG:style_emoticons/default/thumbsup.gif)
http://www.hyundai-forums.com/index.php?sh...c=42361&hl=
AustinJeff
post Nov 25 2009, 11:11 AM
Post #20
I did a quick search for the part and found one. Hyundai may not recommend replacing it, but it looks like there is a filter after all.
Link:
http://www.autopartswarehouse.com/search/?...ission+Filters)
No New Posts Changed Coolant, Power Steering And Tranny Fluid
1 Big B 69 Yesterday, 08:39 PM
Last post by: ken99
No New Posts Transmission Leak Woes
4 02santafe 87 Yesterday, 03:19 AM
Last post by: lovemysantafe
No New Posts Atoz Loosing 1 Inch Of Water In Tank
1 danieleonharper 44 13th March 2010 - 06:34 PM
Last post by: Mr Pogle
No New Posts Transmission Problem
Revs die on my auto when accelerating?
1 04EKC 43 13th March 2010 - 02:18 PM
Last post by: DSHornet
No New Posts Atos Prime Workshop/ Repair Manual
8 dgetz 7,243 12th March 2010 - 05:48 AM
Last post by: kurtdaniel
17th March 2010 - 03:32 PM
Privacy Statement
