QUOTE (PoMansAWD @ Nov 11 2009, 01:15 PM)
Yes, your a/c compressor will cycle when w/s defrost is selected, but the 'refrigeration' portion of your a/c system does not run if ambient temperatures are too low (again, 47-50degF). You're dash lights will light up to reflect what you selected (defrost, a/c, whatever) and the clutch to a/c compressor spins anytime the engine is running. This doesn't mean the clutch is energized and the compressor is being driven. The reason why your a/c system cannot function in low ambient temps is; The refrigerant will be returned to the compressor suction as a liquid still (not enough heat load on system). Compressors can't compress liquid and tend to go boom in the process. This is basic 'heating & a/c' or thermodynamics. Don't take my word for it, ask a real a/c guy if you have doubts.
Joel
I am inclined to agree with you on this but I wasn't sure. Tonight I installed my HIDs and in the garage, the A/C worked fine. That is to say, I saw the cooling fans kick in. Later, when I backed it out I left it running just long enough to run inside and lock the doors. The outside air temp was -13 C. When I returned to the Fe, I hit the A/C and, the light showed it was on but the fans were not running. This is on a warm running engine sitting outside only 5 minutes max.
This leads me into another major defrosting problem I am having which I should start a new thread - please voice your opinion.
