For my i30 comfort, I picked up a set of 16" alloys that came off a standard spec 2006 Mazda MX5 for £120. They are made at the same OEM factory, and have identical offset, PCD and bore as the i30 wheels. I'm planning to use these for summer and keep the 15" set with winter tyres once I've worn out the original rubber.
Might be worth seeing if you like the look of any of Mazda's wheels.... Provided you've used the correct spec, I wouldn't envisage any warranty issues.
This post has been edited by M1 Commuter: Jan 16 2010, 11:23 AM
