I have a 2006 Elantra GLS. The negative battery terminal has become rusted and corroded to the point where the car will not start and the bolt that tightens the terminal to the battery will not move. I have removed the terminal from the battery and tried the standard tricks for cleaning the terminal such as baking soda+water and WD40 to no avail.
I believe my next course of action is to replace the corroded terminal. So, my question is whether it is easier to cut the cable and replace the terminal or replace the entire cable. I am not sure where the other end of the cable terminates; it disappears into the guts of the car.
If anyone has experience with this problem and can offer advice, I would greatly appreciate it.
Thanks.
