I'm at over 42Kmi on my 2008 GLS AWD 2.7L and it saw rental service early in it's life so I figured it was a good idea to get this done. Having already done the transmission drain/fill and transfer case, this was by far the simplest and quickest. I used a 21mm socket for the drain & fill plugs and dropped the spare tire to make for an easier fill, right out of a quart sized gear oil bottle directly into the fill hole. The factory 70w90 definitely came out darker than the T-case oil did with some gray streaks in it, plus there were a few tiny, shiny shavings on the drain plug magnet, where I didn't notice visible shavings on the T-case or trans plug magnets, just black goo. In went a quart of Walmart Supertech 75w90 synthetic blend gear oil. Just shy of a qt came out. It was a good chance to clean up the dirt/stones crusted up on the spare tire and grease the cable winch for the spare. My "compact" spare is a Kumho! I never noticed spares with name brands on them before.
(IMG:
http://i85.photobucket.com/albums/k65/mtpockets06/031-2.jpg)
(IMG:
http://i85.photobucket.com/albums/k65/mtpockets06/032-3.jpg)
Joel
