QUOTE (MsDysie @ Nov 10 2009, 04:08 PM)
DSHornet, thanks for the reply.
The leak appears in the middle at the front. We cannot visually detect anything that appears to be leaking. The leak usually is only a few drops to several drops, creating a damp spot, not a puddle, and has not appeared since the weekend. There is also no noticible change in my temp gauge. I must schedule another maintenance for next week anyway.
Sounds to me as though the mechanics have spilt some onto the floor pan or bodywork when filling/topping it up and as the residue has to get out from under there it drips down to the place you see it. Once it has dissepated there isn't any more so no more wet spots. (bit like grandpa leaking into his shorts, it's only the last few drips (IMG:
style_emoticons/default/smile.gif) )
I would ask the mechanics to be more careful next time as antifreeze can lift off paintwork and they don't need to be so sloppy.
Itza
