> Transmission Not Shifting
taters
post Nov 8 2009, 01:25 PM
Drives: 2001 sonata
When you start off after the car has been parked the trans shifts from 1st to 2nd gear abruptly then to 3rd gear smoothly but will not shift to 4th gear or downshift. Now when you stop the car will only take off in 2nd gear and shift to 3rd gear. Any help would be appreciated
tech1
post Nov 9 2009, 03:21 PM
Drives: 2003 Accent
Check for a code in the tcm. The check engine light should be on.
taters
post Nov 9 2009, 06:33 PM
Drives: 2001 sonata
The check engine light is on. Had it scanned yesterday and these were the codes. P1529 P0720 AND P0715. Any ideas on what I need to get this repaired?
rched2
post Nov 20 2009, 11:59 AM
Drives: 2002 Hyundai Sonata GLS 2.7
QUOTE (taters @ Nov 9 2009, 05:33 PM) *
P0715 - probably due to a bad input speed sensor
P0720 - bad output speed sensor
P1529 - code is for SCAIR - solenoid circuit malfunction but it is likely tied in with the two above and often goes away once the input and/or output speed sensors are replaced.
The input speed sensor and the output speed sensor are probably between $65-$80 if you pick them up at a Hyundai dealership. If you need to keep the repair as inexpensive as possible, try having the input speed sensor changed and then take it for a short test drive.
Is your car having any of these symptoms:
Harsh/jarring park to reverse or park to drive engagement shock
Occasional failure to shift out of first gear until you get close to 5000 rpm and then you get a harsh shift into 3rd gear
Less likely causes for P0715: malfunction of the underdrive clutch retainer, malfunction of connector or malfunction of the TCM
Less likely causes for P0720: malfunction of connector, malfunction of the TCM or malfunction of the transfer drive gear or driven gear
You might need to have the transmission flushed if the fluid is in bad condition.
taters
post Nov 21 2009, 10:42 AM
Drives: 2001 sonata
QUOTE (rched2 @ Nov 20 2009, 12:59 PM) *
No New Posts Transmission Leak Woes
4 02santafe 67 Today, 03:19 AM
Last post by: lovemysantafe
No New Posts Not So Great Review Of 2011 Sonata Gls
2 -Guest_LemonLaw_*- 135 Yesterday, 08:10 AM
Last post by: -Guest-
No New Posts Not Very Happy
10 HyundaiLvr87 364 13th March 2010 - 05:57 PM
Last post by: david-paul-1
No New Posts Transmission Problem
Revs die on my auto when accelerating?
1 04EKC 37 13th March 2010 - 02:18 PM
Last post by: DSHornet
17 BoyRoy 603 8th March 2010 - 07:57 PM
Last post by: LennyR
16th March 2010 - 04:23 AM
Privacy Statement
