QUOTE (yasha @ Nov 8 2009, 02:12 PM)
Hi,
As a new owner of an 09 Santa FE SE, I found another interesting but frustrating tidbit. Apparently, you cannot turn on your headlights without having the key in the ignition? I know this is probably a precaution to prevent your battery from draining but is there a way around this? I really would like to be able to turn on the headlights without having to leave my keys in the car whenever I need to make a quick dash somewhere. Thanks....
RTM!!!...."If necessary, to keep the lights on when the ignition key is removed, perform the following...
1) Open the driver-side door.
2) Turn the parking lights OFF and ON again using the light switch on the steering column.
Hope this helps... (IMG:
style_emoticons/default/00000732.gif)
