QUOTE (Ken SantaFe @ Nov 5 2009, 06:49 PM)
It was the same on my Toyota Tundra pickup. Remove relay, jumper 2 connections. Of course you have to know where the relay is, and which two connections once you expose them by removing the relay. Perhaps someone with a SantaFe wiring diagram can give us some info.
Remove relay ...remove cover from the relay (it snaps on)....... bend or wedge relay contacts to close them permanently......refit relay cover ....replace relay...... job done. I did this on my Terracan.
If you obtain a spare relay to modify it can be swopped back when taking car in for servicing etc.
