> 2004 Fog Light Bulb Replacement How-to
Garrin
post Nov 3 2009, 12:01 AM
Drives: 2004 Hyundai Santa Fe 4cyl
Hi, hope you're all doing well.... I've looked over my 2004 Santa Fe trying to figure out how to access the Fog Lamp Bulbs to replace them but nothing sticks out to me other than removing the bumper.... if anybody has any experience with this I would love to hear from you.
Thanks for your help and time.
Garrin
lovemysantafe
post Nov 3 2009, 06:14 AM
Group Icon
Group: Super Mod
Drives: '04 Santa Fe GLS 4WD (Born 5.24.04)
Ugh...I had a whole write-up written here and accidentally clicked the 'X' on the tab before I could post it. (IMG:style_emoticons/default/angry.gif) Oh well...not your fault. Here it is.
Thankfully you do not have to remove the bumper. Here is a step-by-step for you to follow. It's been about two years since I toyed with mine so this may not be 100% but it's pretty darn close. (IMG:style_emoticons/default/thumbsup.gif)
  1. Remove the headlamps - they use a 10 mm socket
  2. Reach down into the bumper and disconnect the power leads to the bulb. The release tab is on top of the connector, covered by some insulating foam. No need to remove the foam, just push the tab through it and slide the connector off.
  3. Turn the bulb socket counterclockwise to remove it from the fog light assembly.
Once you replace the bulb, make sure you don't touch it with your fingers. Re-installation is not easy and avoiding contact with the bulb is even trickier so just be patient and take your time. Fitting the new bulb in the socket can be nearly impossible if you're looking down from the top because its very difficult to see how the notches line up. Luckily, I found a solution. With the new bulb in your hand, reach down and put it halfway into the socket, then (without letting go) look through the fog light lens and you'll be able to see how the notches line up. This is SOOO much easier than trying to do it blindly.
Reconnect the power leads and test them before zipping everything back up. Good luck and I hope these instructions are helpful!! (IMG:style_emoticons/default/thumbsup.gif)
Garrin
post Nov 3 2009, 12:29 PM
Thank you, I'll give that a shot this weekend (IMG:style_emoticons/default/smile.gif)
EF/ELP
post Nov 7 2009, 12:08 AM
Drives: 2004 Sonata LX
And while you are at it go for the upgrade on the lights, I installed this
http://www.v-leds.com/Exterior-LED/DRL-LED...D-p7652845.html
On my 2004 Sonata and pair very nice with the HIDs.
Good luck.
No new Pinned: Topic has attachmentsReplacement Dvd/gps/tv/bluetooth Unit
711 glospete 49,238 Today, 04:28 AM
Last post by: glospete
No New Posts 2004 Elantra Lag Time Between Shifting And Acceleration
Need to know what the problem is
2 Elantra2004 38 Yesterday, 05:00 AM
Last post by: Elantra2004
No New Posts 2004 Camshaft And Crankshaft Replacement
Covered under warranty
0 monicainnm 34 16th March 2010 - 07:26 PM
Last post by: monicainnm
No New Posts Topic has attachments2004 Hyundai Sante Fe P0441
2 johnbo 47 16th March 2010 - 01:32 PM
Last post by: scarney1988
No New Posts 2004 Sonata Timing Belt Parts
11 Banshee365 112 14th March 2010 - 05:58 PM
Last post by: jsinton
20th March 2010 - 12:16 PM
Privacy Statement
