I searched and read through many posts on this subject but Im still having trouble replacing the bulbs. Im replacing the driver side bulb of my headlight. I removed the battery and Im looking down on the power housing where the wires connect to the headlight unit. My question is...
The clips/grips/tabs that you press to remove the housing from the bulb - if I am looking down on it, they are on either side of the black housing, right? Are they the sort of very small arrow-like looking clips? I squeezed these as hard as i could and pulled but nothing moved. Im afraid im going to break or dislodge anything further inside if i pull too hard. Im wondering if im squeezing the wrong tabs because it seems more-difficult-than-it-needs-to-be.
Is there are 'click' when the tabs are fully squeezed....or can I just pull hard enough with worrying about any damage?
