 Hyundai-Forums.com > Hyundai Models > Tucson Forum
> Transmission Fluid, atf compatibility
racerboy420
post May 18 2005, 07:21 PM
Drives: 2001 hyundai santa fe
Anyone who is curious, I talked to a technician at Valvoline, he told me that Mercon5 is perfectly compatible with all Diamond atf which is used in Hyundais and Mitsubishis including Diamond atf Special M-11, they have tested and used it extensively in their fleet vehicles requiring Diamond atf. Just thought someone would like to know.
hyundai tech
post May 18 2005, 09:49 PM
Drives: hyundai elantra
The only fluid for transmissions in Hyundai vehicles is the sp3 fluid. Any other fluid will void warranty and cause internal damage. This topic has been discussed alot on these forums.
RobNC
post May 16 2008, 02:12 PM
Drives: 2005 Hyundai Tucson
How about Amzoil synthetic ATF:
http://www.amsoil.com/storefront/atf.aspx
In case URL not allowed (due to newbie) please go to www dot amsoil dot com slash storefront slash atf dot aspx
In the USA, it is illegal to force you to use the car manufacturer's fuild. Just look up Magnuson-Moss Warranty Act (here's an example):
http://www.knfilters.com/warrantyletter.htm
AMSOIL ATF is recommended for transmission, hydraulic and other applications requiring any of the following specifications:
* Mitsubishi/Hyundai Diamond SP II & III
SERVICE LIFE
AMSOIL Synthetic Automatic Transmission Fluid is recommended for use up to 50,000 miles under severe service* and up to 100,000 miles under normal service* or according to the vehicle manufacturer recommended intervals, whichever is longer. AMSOIL recommends thoroughly draining the transmission and flushing with new AMSOIL ATF to achieve a minimum 90% purity of new transmission fluid. Drain intervals may be extended further with oil analysis.
* As defined by the vehicle or transmission manufacturer.
This post has been edited by RobNC: May 16 2008, 02:13 PM
Montego
post May 16 2008, 02:41 PM
Administrator
Group Icon
Group: Administrator
Drives: XG's (2001&2002)
the only fluid that is safe for hyundai auto boxes is SP111 or mitsubishi diamond. this topic has come up so many times in the past.....the bottom line is if some of you guys want to believe that other fluids are compatable then go ahead and use them....it's your vehicle and your money if the gearbox fails, the only guy l feel sorry for is the poor guy that buys the vehicle second hand and is faced with a problem that a previous owner has created
RobNC
post May 16 2008, 02:58 PM
Thanks for the reply. I challenge anyone to show proof that Amzoil synthetic ATF caused premature failure of the AT. Actually, the Magnuson-Moss Warranty Act states that if the manufacturer suspects failure, it is their job to prove it (not just say "you didn't use our fluid").
As we all know, Hyundai doesn't make any fluids whatsoever, or oil filters, or oil, brake fluid, etc. If a manufacturer lists a specification for a fluid, and another manufacturer meets or exceeds that specification, then you should be fine.
However, I do agree with what all other posts have said about this in the past (which I haven't read) - that Dexron III and other fluids (with inferior specifications to SPIII) will probably give credibility to premature AT wear and failure.
(BTW I don't work for Amzoil - but luckily for me a guy at work gets it for me real cheap - and it's cheaper than the dealer, which I understand uses a synthetic blend).
:beer:
Montego
post May 16 2008, 03:12 PM
Administrator
Group Icon
as l said it's your choice, your vehicle and your money....if you're convinced that another brand is just as good then use it (but l would'nt!)
RobNC
post May 17 2008, 06:14 PM
BTW, there's a TSB for my vehicle regarding this, just look it up under hmaservice.com (have to login and have the Adobe SVG plugin). Go to 2005 Hyundai Tucson, then Service information, TSBs, AT - Automatica Transaxle, then see 06-40-016. It states:
NOTE: Use only Hyundai SPIII ATF, Diamond SPIII ATF or other brands meeting
the SPIII specification approved by Hyundai Motor Company.
NOTE: SPIII has a red color when new; however, the ATF may change color to a
dark red or brown after 10,000 to 25,000 miles in service. This change is
normal for this type of ATF and does not indicate an internal transaxle
condition.
MAINTENANCE INTERVAL:
Refer to the maintenance schedule in the owner’s manuals for maintenance
requirements:
SEVERE DRIVING CONDITIONS:
• Repeated short distance driving
• Extensive idling or low speed operation
• More than 50% driving in heavy city traffic during hot weather above 90°F (32°C)
• Driving in very cold weather below 0°F (-18°C)
• Towing a trailer
• Driving in mountainous areas
SERVICE CHANGE ATF COMMENT
NORMAL 105,000 miles/84 months
SEVERE 30,000 miles/30 months See definition below
This post has been edited by RobNC: May 17 2008, 06:32 PM
Hyundaiownersclu...
post May 31 2008, 01:54 PM
Drives: Tucson
Chrysler ATF 4+ is a good quality auto oil and it goes in the Hyundai boxes
Pelikan
post May 31 2008, 03:37 PM
Drives: Azera2006 OutBack 2001
That's exactly what Montego said!
You can use ANY ATF that meets or exceed sp3 specs.
labakis1
post Mar 19 2009, 07:30 AM
Drives: MATRIX 1,6 AUTO
I HAVE JUST CHECK THE SERVICE MANUAL -!!!!THE SPF III FLUID IS USED ONLY FOR STEERING!!!!- ----DIAMOND ATF MERCON II etc used for ATs!!!!---
billynoband
post Dec 14 2009, 10:54 AM
Post #11
Drives: outlander
QUOTE (montego @ May 16 2008, 04:12 PM) *
Hello, good forum. This is my first post and I am over here from the Mitsubishi Forum because of a Google search for Diamond sp111 atf fluid bought me here.
I just though I would write on this post because the other post on this subject in this forum has been locked.
The reason most people in the UK are asking about this fluid that Mitsubishi and Hyundai use is because it is very hard to find for DIY use not because they are stuburn or daft. I have only found one main dealer willing to order me some in the uk. £125 for 25 litres but the postage from Scotland to the midlands is not on so I declined.
I have found that all the Mitsubishi main dealers in my area use Castrol multi-vehicle atf fluid when asked. The main problem with the post's on the subject seem to be the fact that people who want to change their own atd fluid cannot find sp111 so then when they ask on the forum what else can I use? they get answer's such as "it's risky to use anything other than Diamond sp111. If people could buy it they would use it.
This recommended sp111 oil is obviously not rocket science as it only costs 4 dollars a litre in asia. I cannot think why anyone would think it's risky to use an alternative, you would not stick Vauxhall 10/40 in a Vauxhall engine all the time, you would not worry if you had to use Mobil.
I used Amsoil in my Mitsubishi which needed Diamond sp111 last year because the Castrol multi-vehicle fluid is not available to the public in the UK either. Opie oils now sell 4 different atf oil's which meet this Diamond sp111 spec, it is £10-£15 per litre. Happy DIY.
While on the subject of fluids the Castrol green coolant/anti-freeze mixes well with the green fluid found in most Asian vehicles I have found. The Castrol spec sheet say's it is designed for this purpose too.
Keep up the good work up.
MiamiLX
post Dec 14 2009, 06:07 PM
Post #12
Hyundai Challenged
Drives: Sonata 2006 LX V6
Welcome new member. Not sure what we learned though? I have a quart of the Mitsubishi. Use whatever you like but remember...
No New Posts Transmission Problems With New 2010 Santa Fe
3 rpm123 109 18th March 2010 - 10:41 AM
Last post by: PoMansAWD
No New Posts Transmission Leak Woes
4 02santafe 104 16th March 2010 - 03:19 AM
Last post by: lovemysantafe
Revs die on my auto when accelerating?
1 04EKC 47 13th March 2010 - 02:18 PM
Last post by: DSHornet
17 BoyRoy 630 8th March 2010 - 07:57 PM
Last post by: LennyR
No new Topic has attachmentsTransmission Shifts
Harsh trans shifts
155 pistol 5,851 7th March 2010 - 04:27 PM
20th March 2010 - 02:01 AM
Privacy Statement
