> Tach, installation
cuban
post Oct 28 2009, 02:00 PM
Drives: 1996 hyundai accent 1.5l custom catback, custom cai, stripped interior, new clutch, more to come....
I have a 96 accent 1.5l and want to install a tach. I hooked it up to the coil but wont rev over 3000 and thats even putting it to the floor. Any help would be greatly appreciated.
atrain
post Oct 28 2009, 07:40 PM
Drives: 1999 Hyundai Accent
universal tachs have different settings for different # of cylinders. What is it showing you at idle? (Should be around 800ish I think.)
cuban
post Oct 28 2009, 08:00 PM
There is a setting 4,6,8. I have it set at 4 and it revs around 700 or 800 rpm. At max rev it shows 3000 in gear or neutral, pedal to the floor. I have installed tons of guages in other vehicles but never a tach in a hyundai.
mac1
post Oct 28 2009, 09:42 PM
Drives: 2001 XG, '01 Accent 1.6L, '98 Explorer Sport, '95 Probe GT-Turbo weenie
well since no one else has pointed it out, guess i'll be the first. And let me know if it works as i'm gonna do the same. Do you have an auto or stick? pin 52
(IMG:http://hmaservice.com/data/Passenger/HY/HMA/ENG/SHOP-Images/HY-X313-IMAGES-ENG/A5SD112B.gif)
This post has been edited by mac1: Oct 28 2009, 09:43 PM
cuban
post Oct 28 2009, 09:48 PM
I have the five speed. The instructions said to look for pin 52 and its green yellow/white wire. Founds tons of them but I guess not the right one.
mac1
post Oct 31 2009, 12:44 AM
remove the connector from the ecm, undo the plastic housing so you can see the wires going into the pins. Now turn it around so you see the side that connects to the ecm and count from right to left starting at upper right corner. Count 52 pins over and see if it lands on that wire. If you're not sure what side of the connector is upper right then try it a few times till you land on the correct pin number and wire color. And since yours is a a stick with no TCM that means it will probobly be white.
This post has been edited by mac1: Oct 31 2009, 12:45 AM
understated
post Nov 7 2009, 03:36 AM
Drives: 1996 Hyundai Accent/Excel X3
On the ECU pin the RPM signal wire is the 6th pin from the right (with the plug facing away from you) on the top row, the row with 19 pins (both other rows of pins have 18). I suspect you have the wrong signal wire.
chaz108
post Nov 27 2009, 08:51 PM
Drives: 1996 Hyundai Accent GT 1.5L DOHC 16V
Does anyone know how to install an Autometer Monster tach with shiftlight in a 1996 Hyundai Accent GT 1.5L DOHC 16V? I wanted to attempt doing it myself before taking it to some exspensive shop just to have a tach installed. Any help will be appreciated =) p.s. my car has the stock tach in it as it is a 5 speed manual is there anyway i can just piggyback off the wires running into the stock one?
xKryptx
post Mar 6 2010, 02:46 PM
Drives: 1996 Hyundai Excel (X3) 5 Door GLX
Okay, i have a manual on my lap here, and according to it BEHIND THE CLUSTER!!!
its the WHITE wire, tap into it and tacho shall be enabled.
the joys of having a stage 2 cluster already (IMG:style_emoticons/default/smile.gif)
xKryptx
post Mar 6 2010, 02:48 PM
QUOTE (chaz108 @ Nov 28 2009, 12:51 PM) *
you might want to disable the stock one as the pulses may be halved due to running two tachos.
Not 100% on this but hey... it may happen.
No New Posts Tachometer Not Working
1 tr3ndsetta 16 15th March 2010 - 09:32 PM
Last post by: jsinton
No New Posts 94 Excel Gs - Tach Not Working And Check Engine Light
1 jkw_excel 18 15th March 2010 - 03:31 PM
No New Posts Problem With Attached Files
7 burnitwithfire 49 13th March 2010 - 11:46 AM
Last post by: burnitwithfire
No New Posts 2000 Sonata Tach Issues
0 vhenem 24 7th March 2010 - 03:46 PM
Last post by: vhenem
No New Posts Topic has attachmentsPutting A Rpm Tachometer
Help
5 Gerrito225 2,037 2nd March 2010 - 03:04 AM
Last post by: epinero
20th March 2010 - 10:03 AM
Privacy Statement
