 Hyundai-Forums.com > Hyundai Models > Tucson Forum > Fuel Consumption
> Disabling Awd
Unclestanky
post Oct 26 2009, 10:35 AM
Drives: 2005 Tucson GL 2.7
My '05 2.7L Tucson AWD gets terrible mileage. My old Subaru had a fuse that you could pull out that essentialy turned it into FWD only. Since there are only a couple of months out of the year that I really need AWD, I was wondering if there was a similar ability with the Tucson and, if so, would it make any noticeable difference in the mileage? In the Subaru, I noticed a 2-3 mpg increase. Thanks!
itza
post Oct 27 2009, 10:09 AM
Expert
QUOTE (Unclestanky @ Oct 26 2009, 04:35 PM) *
Hi
The Tucson although 4 wd only uses 2wd and brings the other 2 in when its needed ie wheels slip etc. Its an intelligent 4wd and this is fully electronic and cannot be partially disabled.
Ref your fuel first clear the memory on the computer by taking off a battery terminal and then sit in cab for 5-10 min without it switched on pumping the brake pedal this clears the memory- stick the terminal back on and take it out for a 20 mile ride using the best places to go without traf lights etc such as a freeway. take it up to the top gear by modestly pushing down on the loud pedal and then cruise around 50/60 then take it home this way the ecm will have learned a different way to drive and fuel consumption should now be a bit better.
Keep an eye on tyre pressures and if not inconvenient only fill up to half a tank at a time say 30 litres as then you are not towing round all that dead weight.
You should be better off (I hope), the leaded boot is the most dangerous part of the fuel consumption issue of which I am certain you are aware.
Cheers
Itza
No New Posts Topic has attachmentsAwd And Reverse
4 newSFowner 247 9th February 2010 - 11:11 AM
Last post by: Don67
No New Posts Awd System!?!?!?!?!?
I`m a bit confused...
1 Dino Kirov 214 25th October 2009 - 03:53 PM
Last post by: lovemysantafe
No New Posts Disabling Tpms
How do I disable the TPMS subsystem
1 dac122 252 1st September 2009 - 09:11 AM
Last post by: jsinton
No New Posts Awd Lock + Traction Control
traction control function with AWD lock
22 saraph 1,450 6th August 2009 - 12:00 PM
Last post by: Dino Kirov
No New Posts Awd Lock Switch Function
11 AlaskanAWD 458 22nd June 2009 - 12:33 PM
19th March 2010 - 12:35 PM
Privacy Statement
