My 2006 Limited's battery began to give problems just under the 2-year point and the dealer replaced it for free, no pro-ration under 2 years.
They can quickly enough determine if it IS the battery or if it's the charging system. If the battery itself is the problem, anything over $70 for simply replacing a battery is a total rip, and the replacement had better be an Interstate or better.
The dimming while driving is due to a ground terminal in the wiring harness not making the best contact with the chassis. While I never had the problem, some who have had their battery replaced found that their dimming problem went away, most likely being that the battery ground terminal was shifted/tightened, resolving that part of the problem...
