Tranny Flush |
Oct 21 2009, 04:19 PM
Status:
Drives: 2006 Hyundai Azera Limited, Sonata LX 6
I have 25,750 mi. on my 06 Azera Ltd. and based on the fact that the car is in service just over 3 years I had a transmission flush (no filter change) at a cost of $240.00 at the dealer. Does this sound like it's in the ballpark? I have never had any problems with the transmission whatsoever. (IMG: style_emoticons/default/liebe011.gif) Don
Oct 21 2009, 04:32 PM
Status:
Drives: 2007 Hyundai Azera
I'm scheduled to have mine done Monday after about 30K miles. I thought the filter change would be standard with the flush. I'm going to check with my dealer. I didn't even ask about the cost and had no idea it would be $240.00. Sure hope not may have to consider using another service shop.
Oct 21 2009, 08:31 PM
Status:
Drives: 2006 Azera Limited, Premium pkg, built Jun 13, 2006, Aubergine in color, 44,000 miles and counting...
I had the complete 30k mile service done for $297 last year, tranny fluid and filter, oil and filter change, cannister air filter change, engine air filter change, rotate tires, lots of inspect this and that...
Oct 22 2009, 09:28 AM
Status:
Drives: 2007 Hyunda Azera 3.8
Had my transmission flush at 45000. only did fluid no one will change filter any more it cost just under $200.00
Oct 22 2009, 03:28 PM
Status:
Drives: several
QUOTE (petergun @ Oct 22 2009, 07:33 AM)  I would bet that the dealer does not do such a comprehensive check. Transmission fluids nowadays do not have to be changed that often unless you beat the crap out of your car and overheat the transmission one too many times. It is also more usual for transmissions to die in the Southern parts of the US due to the heat. However, the transmission fluid in the Azera is semi-synthetic and pretty darn good. All I did was drain the fluid that was in the pan and added that amount back. This is sufficient for day to day driving. A dealer will nickel and dime you to death if you get everything they ask for. However, I can do my own checking on the car so that is a personal advantage. Oh well. Such is life. Your Hyundai Azera does not have semi-synthetic fliud from the factory.Unless you have put it in it! SPIII $8.50 a quart! Take a look at this chart. http://myhyundaiforums.com/ATFSpecifications20080903.pdfVery good info on Hyundai Fluid Specifications! Shawn
Oct 22 2009, 04:04 PM
Expert
Status:
Drives: 2001 Subaru Outback & 2006 Azera Premium
QUOTE (shawn4547 @ Oct 22 2009, 04:28 PM)  Your Hyundai Azera does not have semi-synthetic fliud from the factory.Unless you have put it in it! SPIII $8.50 a quart! Take a look at this chart. http://myhyundaiforums.com/ATFSpecifications20080903.pdfVery good info on Hyundai Fluid Specifications! Shawn The Hyundai SPIII is a semi synthetic or synthetic blend as per my dealer.
Oct 22 2009, 06:34 PM
Status:
Drives: 2007 Hyundai Santa Fe 3.3 LTD
I did a drain and fill of the tranny fluid in my '07 Santa Fe at ~30k miles. Purchased 6 quarts of the Hyundai SPIII at $6.47 / quart from my dealer. Hyundai/KIA/Mitsubishi dealers carry the SPIII fluid which is indeed synthetic blend. Call around to see if you can find a better price.
Oct 25 2009, 12:37 PM
Status:
Just an addendum to my original post. My 06 Sonata LX6 has 13,000 mi. and is just over 3 1/2 years young. It is driven carefully and upon inspection the tranny fluid still has a reddish color and no odor. My service adviser at the dealer initially suggested that I change the ATF based on age. I resisted with the statement that it appears to be overkill on their part. I asked what if..... I had transmission trouble at this low mileage would the warranty be honored? He acknowledged that yes it probably would due to the low mileage. My question is can the tranny fluid breakdown due to age at low mileage, taking into consideration that visually it still seems to be in pristine condition? (IMG: style_emoticons/default/liebe011.gif) Don
Similar Topics
Similar Topics
